2003 track with OEM navigation problem
Somethings wrong with my OEM navigation. Stupid maintence information keeps popping up! its soo annoying!!! when i plan a route 10 secs later the stupid maintenence information pops up!! I press CANCEL or MAP and it comes back on in like 10 secs! is this a bug? Has this happen to anyone here before? the maintenece information is the window that shows up when you press INFO
i'm assuming its not the green screen that tells you you're overdue for maintenance...
does it only happen when you have a route set?
if so, it could be the software. now is a good time to update, just check craigslist
if it happens all the time with or without a route set, i would check the "INFO" button. Pop the key pad out and press cancel or map then unplug it and see if it goes back again.
The OP did a double-thread, posting the same question on two sub-forums.
Go to the Audio & Video subforum to post replies and abandon the thread on this sub-forum.
Why do people do that (post the same thread to multiple subforums)?
--Spike
--Spike
^^ You are correct...agree with you, but beyond this; responses should be directed to:
https://my350z.com/forum/audio-and-video/327932-2003-track-with-oem-navigation.html
... and only because he started two identical threads.
--Spike
EDIT: Hopefully a my350z.com Moderator reads this thread and locks it so any information goes to the other thread the OP started.
--Spike
gosh this is worst than honda forums... both of my threads someone is flaming someone... anyway i notice this only happens when its hot outside, when its cold at night the maintainence info. never pops up. i will try to do an upgrade since my CD is the first one that came out 2002 or something! anyway thanks for the help.
liqalu04
Jan 2, 2022 12:58 PM
