Codes???
Old Feb 14, 2008 | 03:38 PM
agallardo's Avatar
agallardo
Unhappy Codes???
Well I have an 04 350z. I know its still under warranty, but I put XS Power test pipes, Greddy TT Evo2 catback, Eibach Lowering springs, and have a plenum ready to be put on. So I believe with all this installed, it would void the warranty, UNLESS i put everything back on, which would be a pain. So I would like to eliminate that problem. Anyway, if anyone can help me out with these codes, it would be awesome.
P1273
Manufacurer Contrl.
Fuel Air Metering
P0442
EVAP emission
Control System
Leak (small)
I did some research and went to an OBD website and got this:
P1273= Cylinder#3 High to Low Side Open
And I just assume the Evap emission might be from relocating the Canister behind the car, because we just installed the exhaust, OR could just be the gas cap.
ANY IDEAS?
Old Feb 14, 2008 | 03:47 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
1273 is a problem but i would bet the evap is because a hose is off or gas cap.
Old Feb 14, 2008 | 04:04 PM
agallardo's Avatar
agallardo
What would you think 1273 would be?
Old Feb 14, 2008 | 04:30 PM
DavesZ#3's Avatar
DavesZ#3
1273 indicates that A/F sensor 1 is reading a "too lean" condition.
If you put test pipes on without a non-fouler, then that's probably your problem.
Old Feb 14, 2008 | 05:13 PM
Tim@WestCovinaNissan's Avatar
Most likely right on the 1273. The evap problem is most likely either a hose is not tight or routed incorrectly.
Old Feb 14, 2008 | 05:59 PM
agallardo's Avatar
agallardo
I do have sparkplug non-foulers on.
At first, it shot out the 02 sensor codes. So I got the spark plug foulers and put them on. The Service Engine light stayed off for 3 days and came on today.
Old Feb 14, 2008 | 06:59 PM
agallardo's Avatar
agallardo
Anyone else have any other ideas?
Old Feb 14, 2008 | 07:05 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
1273 is too lean bank one i have 1283 its b2 lean noone really has any idea how to fix it some say the sensor ohers have no clue i dynoed and wasent running lean.
Old Feb 14, 2008 | 07:56 PM
agallardo's Avatar
agallardo
So what do you do about emissions?
Old Feb 14, 2008 | 08:03 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
well for me i have the light on only sometimes i have a code reader being a mechanic i clear it and drive it to get it tested and never turn it off it i have found out it only happens at idle i think it must have something to do with how freely the exhaust flows through. If i dont shut it off the test goes through ok and the second i turn it off and turn it on it comes back. As best i can tell its no real problem
Old Feb 15, 2008 | 02:29 AM
agallardo's Avatar
agallardo
Well I work for advance as well, and I have an OBD scanner there. I had cleared the codes earlier yesterday, and literally came back on sitting throught the drive-through at McDonalds about 3 hours later...
So yours stays off as long as you are driving?
Did some more research and found this:
http://forums.nicoclub.com/zerothread/182298
And right next to 1273: P1273 Air/Fuel Ratio Sensor 1
None of this is major though? Is it okay to drive my car around like this??? Emissions is the only thing that has me worried.
Old Feb 15, 2008 | 08:52 AM
agallardo's Avatar
agallardo
Anyone else?
Old Feb 15, 2008 | 08:53 AM
phreaktor's Avatar
phreaktor
Design Engineer
ABACABB- Ikari Warriors respawn cheat code
Old Feb 15, 2008 | 10:10 AM
agallardo's Avatar
agallardo
What does this mean:
http://www.obd-codes.com/trouble_cod...d/DTC_2004.htm
This is what that link says for that code:
P1273 - Cylinder 3 High to Low Side Open
DESCRIPTION: Indicates a high voltage condition exists at the injector output of the NG module for cylinder No. 3 when low voltage is expected. Fuel injector No. 3 output circuit short to voltage.
POSSIBLE CAUSES: Injector. NG Module.
DIAGNOSTIC AIDS: PID Data Monitor INJ3F fault flags = YES.
Old Feb 15, 2008 | 01:36 PM
DavesZ#3's Avatar
DavesZ#3
It means nothing, those are from a Ford. Codes over 1000 are manufacturer specific.
Below is the description from the Nissan FSM.
Old Feb 15, 2008 | 02:17 PM
agallardo's Avatar
agallardo
Any suggestions to fixing the problem? Is it worth putting stock exhaust back on to take it to the dealership? I put the test pipes and catback. I really want to avoid the dealership.
Old Feb 15, 2008 | 02:29 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
well no all they are goin to do is clear it and wait for it to come back doubtful they will replace the sensor that is the only thing ive heard may work. and ive been driving my car with it on like almost a year and no problems. its a idle thing not a driving thing if i do in town it stays out for while its more when i do hw and then in town it comes on quick or alot of stop go.
Old Feb 15, 2008 | 03:14 PM
agallardo's Avatar
agallardo
Put does it not affect performance?
Old Feb 15, 2008 | 06:24 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
P1273
Manufacurer Contrl.
Fuel Air Metering
This could be a bad sensor, a small exhaust leak. This code relates to the upstream 02 sensors...not the ones in your test pipe.
And then again....the mods might just be making your car run a little lean, and its causing this code.
I would definately double check for intake and exhaust leaks everywhere.
The Evap thing is from relocating your evap canisters, and maybe a hose is kinked, or misrouted.....should be an easy enough fix.
Old Feb 15, 2008 | 06:25 PM
Sharif@Forged
Forged Performance
Nope....
Of course, with an optimized retune with the UTEC, there is probably 10-15whp on the table for you.
