HID headlights arent as blue any more
Hey i have been noticing that my headlights havent been a blue lately. I was wondering if my HID needs to be replaced. Its a 03 model. they dont seem to be as bright anymore either.
they were plenty bright enough when i first bought the car but the blue has started goin away and i didnt know if that was a sign of the headlight bout to burn out, anyone have any idea of how much the bulbs cost
its probably your eyes, but in any fashion you can purchase a higher output bulb which can make it "more blue" and brighter at the same time. Look around you can find something. Wont cost you that much on the scheme of things.
well the dealer told me that when the bulb is getting ready to burn out that they will start dimming and turning a slight redish color. When it does that it means the bulbs are ready to burn out soon so i think i might need new bulbs
I thought the same thing with my 04 a long time ago. I solved that problem by upgrading to the 06's! It's probably your imagination, but it wouldn't hurt to upgrade to a higher output bulb. They're cooler anyway!
HID capsules actually dim slightly over time. They colorshift as they age. This is a normal characteristic and it will actually make the light more blue as it ages. The real reason you see blue with most HIDs, is because the surrounding light is so much more yellow it makes the light off your headlamps look blue. On full projector setups, there are other reasons for the color you are seeing, but in reference to the 03-05 headlamps, the reason is in the surrounding light. HID capsules should last at least 5 yrs, and upwords of 10, so I doubt they need to be replaced yet.
Originally Posted by Zivman
let me try to explain a few things here.
