Manual Transmission Fluid Replacement
Old Mar 16, 2008 | 01:22 PM
sundevil67's Avatar
sundevil67
Default Manual Transmission Fluid Replacement
I had my manual transmission fluid flushed and replaced at the local Jiffy Lube yesterday, and today it is much harder to move through the gears...seems to get a little stuck like I am breaking in a new transmission. Is this a normal side effect of this procedure, or did they put some garbage in my car that I have to get replaced?
Any insight would be appreciated.
sundevil67
Old Mar 16, 2008 | 01:24 PM
SuperBlack350z's Avatar
SuperBlack350z
what type of fluid did you put in there? What viscosity?
I would never take my car to jiffy lube for anything. For all you know, they didn't do anything.
Our car takes GL4..and most places wouldn't know.
Old Mar 16, 2008 | 02:13 PM
sundevil67's Avatar
sundevil67
I hear ya - I never would have gone to Jiffy Lube when I thought I was keeping the car, but now I just don't seem to have the time or energy to put too much extra effort in, and Jiffy Lube is definitely more convenient. Of course now it is going to turn into a huge pain, so in the end I should have just gone someplace better.
Is there any long-term 'danger' to other components to using an incorrect viscosity?
Thanks.
sundevil67
Old Mar 16, 2008 | 02:22 PM
350ZTheStandard's Avatar
350ZTheStandard
Are you serious asking this???
Old Mar 16, 2008 | 05:37 PM
Eazzy's Avatar
Eazzy
Some say after a change, it shifts like butter, so I just used butter. It shifts like gear lube
Actually I use Motul
Old Mar 17, 2008 | 06:54 AM
Tim@WestCovinaNissan's Avatar
First off...a transmission flush on a manual is not possible. There is not fluid pressure to perform the flush like you would on an automatic. Yes if the incorrect fluid is used it can cause serious problems. The only service that can be done is a drain and refill.
Old Mar 17, 2008 | 02:10 PM
krnzzang84's Avatar
krnzzang84
Didn't jiffy lube get caught doing scam where they say they would do a job and never performed.. anyways... I would not trust jiffy lube. NO they can't even touch my car!!!
Old Mar 17, 2008 | 02:28 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
yeah its supposed to shift like butter...so if i were you id drain out whatever they put in there and refill it with something better like Motul.
Old Mar 20, 2008 | 11:37 AM
HOMiEZ's Avatar
HOMiEZ
agree with everyone so far.
while we're on this subject how often have u guys replaced your MT fluids?
Old Mar 20, 2008 | 11:51 AM
Bevo's Avatar
Bevo
I do it every 30k miles with Nissan fluid
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
