New clutch feels almost worn out?
Old Mar 21, 2008 | 02:40 PM
Rommy's Avatar
Rommy
Default New clutch feels almost worn out?
Barely has 350 miles on the new clutch, but it's engaging when the pedal is almost completely released. It's an OEM clutch. Can the clutch engagement point be adjusted in any way?
Or did I screw up the clutch already in only 350 miles? Lol. Only stalled it a few times, honestly. Do OEM clutches screw up that quickly?
Thanks!
Old Mar 21, 2008 | 02:43 PM
SuperBlack350z's Avatar
SuperBlack350z
at least wait until the clutch is broken in. At 350 miles, it's hard to tell. Brand new 350z's pedal releases all the way at the top anyways.
Old Mar 21, 2008 | 02:50 PM
Rommy's Avatar
Rommy
Really now, are you sure? It feels as though the clutch is almost completely worn out already because of this. Maybe I'm just paranoid?
Old Mar 22, 2008 | 08:45 AM
kramykram's Avatar
kramykram
actually i just installed a clutch in my boys 06, but did not go back stock. there was hardly any pedal at all. i had to make a new slave cylinder pin. jack up the car and where the slave cylinder runs into the arm and see if there is any slack. they actually make an adjustable pin.
Old Mar 22, 2008 | 08:58 AM
UHATEIT's Avatar
UHATEIT
if you use the search thread there is actually a clutch height engagement point mod that you can do to your z to allow the clutch to engage at a lower poitn making the car much easier and faster to shift and driev with in traffic. Do a search for that and you may be able to adjust the height and fix the problem.
here is the link to the thread:
https://my350z.com/forum/showthread....shorten+clutch
Old Mar 22, 2008 | 09:00 AM
350ZTheStandard's Avatar
350ZTheStandard
Did you bleed the the clutch cylinder??
Old Mar 22, 2008 | 09:34 AM
Rommy's Avatar
Rommy
I didn't do the install; dealership did. I'm assuming they would bleed it. I've had a new clutch, flywheel, master cylinder and slave cylinder installed in the last two weeks.
Old Mar 22, 2008 | 09:40 AM
Rommy's Avatar
Rommy
You're my hero. I'm doing this immediately.
Old Mar 23, 2008 | 08:02 PM
TouringThe350's Avatar
TouringThe350
Just had the same done last week.. have about 300 miles since install of new OEM clutch and new OEM transmission (3rd gear made a slight grind every now and then- nissan dealer yanked the trans and put a new one in under warranty- I'm still shocked as all hell.) Clutch was SUPER touchy when new- now is very soft and seems to engage kind of late. I'm comparing this to the new clutch feel and my old trans/ clutch with 40K.... I liked my 40K clutch better. I think I'll do this mod over the next weekend with adjusting the pedal- seems liek what I need.
Thanks!! A just to throw out a plug, Victory Nissan of Macomb, MI is the best!
Old Mar 24, 2008 | 11:17 AM
Rommy's Avatar
Rommy
I tried the mod, it didn't really help much, believe it or not. My 3rd gear is grinding once in a while when I put it in too! What did they tell you was causing that, and what year is your Z?
Old Mar 24, 2008 | 06:41 PM
TouringThe350
Didn't say what the exact cause was, just "Failed Synchros- metal shavings in case."- it's an 06' with 42K.
My 2nd gear every now and then crunches since they put it in.. I like to think it's just break in... but...
Old Mar 24, 2008 | 08:10 PM
eltness350's Avatar
eltness350
The Untouchable
just like any aftermarket clutch...500mile wear in....NO BEATING ON IT.....
Old Mar 25, 2008 | 03:12 AM
TouringThe350
Deffinetly! Durring the break in period- I feel like I drive a Kia Rio- got grandpa's in Buick Park Avenues blowing by me at the light.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
ablaine
Nov 29, 2016 10:13 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
