Belt squeal
Old Apr 9, 2008 | 04:47 PM
Mikerosa's Avatar
Mikerosa
Default Belt squeal
usually when the motor is cold, i get a belt squel, its kinda annoying but goes away usually after a few seconds. All the belts are in good shape, and i did spray some belt dressing on there, no dice. What ya guys think it may be? Thanks in advance!
Old Apr 9, 2008 | 06:29 PM
Black_Sunshine's Avatar
Black_Sunshine
Check the tension. An old trick is to put a little dab of toothpaste on the belt, but that was better for V-belts. I'd put my money on the tension, a service manual should show the proper amount of deflection.
Old Apr 9, 2008 | 07:15 PM
CSF's Avatar
CSF
had the same thing...adjusted the tensioner and it's gone
Old Apr 9, 2008 | 07:40 PM
Mikerosa's Avatar
Mikerosa
awesome, you give me hope my friend. cant wait til' tomorrow morning im gonna tighten it, then start it and prey! lol
Old Apr 9, 2008 | 08:13 PM
350 Rookie's Avatar
350 Rookie
you might not have to tighten it, it could be loose.
The best way to check the tighteness without a tool is to turn the belt. if you can turn the belt more than a 1/4 turn, its loose. It should only be able to turn 1/4 turn.
Old Apr 10, 2008 | 04:26 PM
Mikerosa's Avatar
Mikerosa
belt felt tight to me, so i just took it to my mechanic, he said the belts needed to be replaced even though others told me they were fine, wala no squeal anymore!!! Im so pumped
Old Apr 10, 2008 | 10:20 PM
350zx6r's Avatar
350zx6r
good to see this thread everyone cause my Z is squeaking like a bi*ch and my dealer told me to have that 30,000-mile service done which runs about $500+TAX
how can I have this checked or can I just have the belt replaced? cause I dont have that cash right now, oil change is done about to get done, air filter changed and wiper blades changed. my car is an 06 and has 36,000 miles and to be honest I havent done any service to it beside the oil change every 2,500 miles. (REGULAR OIL) and switching to syntetic now.
Old Apr 11, 2008 | 06:04 AM
iknowitsfast's Avatar
iknowitsfast
something in my car, think its the belt is SQUEALING and my volt meter needle jumps way past the '16'. I really hope its just a loose belt..*prays*
Vigman
Nov 17, 2015 04:34 AM
Fixxxercask
Nov 9, 2015 11:10 AM
samansharif
Sep 25, 2015 12:31 PM
Calinismo350z
Sep 14, 2015 04:04 PM
