Clutch noise?
Old May 7, 2008 | 12:08 PM
`tommy's Avatar
`tommy
Default Clutch noise?
Hey everyone,
I have an 07' 350z. It's got about 8k miles on it now and I'd say around 1-2000 miles ago I began to hear a noise when I pushed the clutch in and upon release. It's not a loud noise, and tough to hear with music on. I was just wondering if this is normal. I've read some people saying the clutches are loud, is this what they are talking about? If I could describe the noise I would have to say it sounds like that noise you can make with your tongue when you 'pop' it. Sorry for the crappy description, but any thoughts on this?
Old May 7, 2008 | 12:13 PM
rotchcrocket04's Avatar
rotchcrocket04
Same thing happens to me (2005 w/ 24k miles). However, after doing research (with the Search button finding the Top 100 Questions thread) it has been stated that this is normal. I really only ever hear it in first... however, I would assume that because I'm rolling in every other gear, the road noise drowns it out.
I wouldn't worry about it, although if you are... try searching.. it may prove quite useful.
Old May 7, 2008 | 12:29 PM
rotchcrocket04
I went to the trouble to find the quote for you...
Originally Posted by Wired 24/7
Q: Do all Z's make a "clunk" or "chatter" sound when disengaging the clutch? Is it normal to hear a whirring or slight grinding noise when the clutch is engaged at idle?
A: Yes, these sounds are totally normal. Furthermore, the Z's transmission is rather noisy. Shifts will seem especially noisy when you are in an enclosed parking lot, tunnel, etc.
Old May 7, 2008 | 12:36 PM
Clipdin's Avatar
Clipdin
SHIFT_happens
Have you taken your car in for the slave cylinder recall yet?
Old May 7, 2008 | 09:58 PM
Nismo1182's Avatar
Nismo1182
the flywheel is 2 piece and chatters when the clutch is pushed in
Old May 7, 2008 | 10:00 PM
malibuboy54's Avatar
malibuboy54
x2......the noise is most prominent when cold or just starting up....
Old May 8, 2008 | 10:03 AM
HeadKase's Avatar
HeadKase
my '06 makes that noise whether the car is cold or warm... doesn't seem to be worse under either condition... it's just really annoying... i'd also have to say like others that it's more so when disengaging from first to go to second or to neutral... i'm curious if anyone has swapped their slave cylinder with a different z to see if that helps with 2 things, stiffening the clutch and to reduce that clunky disengaging sound, i helped a buddy of mine swap his '05 slave cylinder for an '03 slave cylinder in his S2K and that helped with "snappier" shifts and a stiffer clutch
Old May 8, 2008 | 11:48 AM
rotchcrocket04
I would imagine that it wouldn't make a difference. I'm solely basing this opinion off the fact that everyone I've ever talked to (whether it be an 03 or an 07) has this noise?! I don't know for sure though... and I don't know if that Slave Cylinder recall would make a difference either.
Old May 8, 2008 | 08:52 PM
`tommy's Avatar
`tommy
Thanks for the info all. And no, I haven't taken my car in for the recall. I never recieved a notice from Nissan so I don't think my car was apart of it.
Old May 8, 2008 | 09:31 PM
lionheartednyhc's Avatar
lionheartednyhc
its normal
/thread
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
