OIl PSI question!?!?!
Old May 28, 2008 | 03:53 PM
aarantes's Avatar
aarantes
Default OIl PSI question!?!?!
Sorry for not searching guys I know I usually tell people to but I dont have time right now.
I just had a new non rev up engine put in on my 05 and in the last two weeks my PSI has slowly been going down. Now when I sit at idle it is almost at 15 psi is that normal or am I just freaking out.
Thanks in advance
Alex
Old May 28, 2008 | 04:10 PM
coachk's Avatar
coachk
Relax....its fine.
Old May 28, 2008 | 04:15 PM
aarantes's Avatar
aarantes
alright so I am fine with it sitting at 15 psi I never really payed attention to it before until after I got my new engine put in.
I would have checked the manual but the previous owner must have got rid of it
Old May 28, 2008 | 04:16 PM
Jay'Z's Avatar
Jay'Z
what oil do you run? 0w40 made my psi 20-25.. 10w40 im at 30-35psi.. I usually idle at 30psi... But yes it could be that low.. Sounds pretty low to me though...
Old May 28, 2008 | 04:20 PM
coachk's Avatar
coachk
Just make sure your oil levels are good...Do you know if the new motor has a oem size oil filter or does it have a bigger one. Sometimes that makes the oil pressure a little off.
Old May 28, 2008 | 04:50 PM
HondaKiller's Avatar
HondaKiller
with oil pressure that low at idle your idle must be irractic? Even with 5-30RP i idle once fully warmed at around 25-30psi. 30psi solid with the a/c on. I would check your oil level make sure it isn't low.
Old May 28, 2008 | 04:53 PM
aarantes's Avatar
aarantes
Well I thought it was my oil level so then I went and got my oil changed because it was time anyways. It still stayd around 15-20 PSI at idle.
I use regular oil filter and 5w-40 mobil 1 synthetic oil
Old May 28, 2008 | 05:07 PM
Jay'Z's Avatar
Jay'Z
Try 10w30.. or 10w40..
Old May 28, 2008 | 05:51 PM
aarantes's Avatar
aarantes
Actually nevermind it was 10w-40 that I used (just went downstairs and found the bottles)
Old May 29, 2008 | 08:09 AM
aarantes's Avatar
aarantes
Bump should I worry or just drive it till something happens. I do still have 7k miles on the waranty.
Thanks
Alex
Old May 29, 2008 | 10:56 AM
rotchcrocket04's Avatar
rotchcrocket04
Seems a little low but as long as your levels check out, I wouldn't worry.
Just changed my oil the other day (M1 5w30 Synthetic) and mine idles a little higher than that... somewhere around 25 I believe. Personally I wouldn't worry if I were you.
Old Aug 9, 2008 | 06:10 PM
ag4670's Avatar
ag4670
Is it safe to be about 15 or alittle lower maybe 10 I checked the oil and its everything seems good I'm running 10w30 and change the oil at 3000
Old Aug 9, 2008 | 06:13 PM
Crom's Avatar
Crom
w/o a oil cooler I'm at 25psi w/ I'm at 35psi
Old Aug 9, 2008 | 06:33 PM
ag4670's Avatar
ag4670
Huh I got 76k on the car now and I noticed after I swapped my headers and add test pipes oil started disappearing and oil psi looks like it went down
Old Aug 11, 2008 | 05:13 AM
rotchcrocket04
Headers and test pipes and now you're burning oil?
With regular oil changes I've seen alot of people run low (around 10 or 15psi). I really don't think it's anything to worry about. However, recently starting to burn oil is something to worry about.
How long have you owned the car? What year?
burglapfd
Dec 6, 2020 01:04 PM
issyz
Jul 2, 2017 03:04 PM
Stevo Z
Oct 3, 2015 09:14 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
