350z motor knock
Old Jul 15, 2008 | 09:43 AM
bmac350z's Avatar
bmac350z
Default 350z motor knock
i recently lost my license and my z has been sitting for about a month, cranked it and started knocking for a few seconds then it got quiet. i am running synthetic oil anyone got any ideas?
Old Jul 15, 2008 | 02:10 PM
R-TuneZ's Avatar
R-TuneZ
old gas. if it stopped, dont worry about it, it is your car retarding the timing to prevent detonation. fill up with highest octane gas available to you.
Old Jul 16, 2008 | 09:36 AM
bmac350z's Avatar
bmac350z
i cranked it and it didnt sound like a spark knock sounded like a rod knock, but it was very low on gas and seemed to idle a little rough but stopped immediately and the noise got quieter then went away after about a minute
Old Jul 16, 2008 | 09:58 AM
pmohr's Avatar
pmohr
Most likely just the timing chain tensioner, took a little bit for it to get primed with oil.
Old Jul 16, 2008 | 10:00 AM
HondaKiller's Avatar
HondaKiller
yeah, sounds like a classic case of timing chain chatter. Although unacceptable it is quite common.
Old Jul 16, 2008 | 12:48 PM
bmac350z's Avatar
bmac350z
so think i should be worried or is there something i could replace to make it stop or is it just maybe because there was no oil in the top of the motor and it had to prime itself? i only have intake ,exhaust and throttle body spacer should i be worried about reliabilty with more mods? its got 75,000 miles and saw on another forum that a z motor threw a rod at 88,000 is this normal life of one of the vq's? ive never heard anything like it and my buddy said they were probably sprayin the **** out of it. all the feedback is appreciated
Old Jul 16, 2008 | 01:31 PM
HondaKiller
unless it is knocking when your driving i wouldn't worry about it. If it is timing chain chatter than there is nothing you can do about it "within reason" I'm sure theres a fix but it is not cost affective.
Indeed it is from the circulation of oil to the top of the motor on a cold start will be delayed just enough for the chain to rattle. I've notice it is pretty random and only occurs when it is really cold out or the car has been sitting for a couple of days. Mine has done it since '04 when i got the car and comes and goes with no noticeable negative outcomes.
Old Jul 31, 2009 | 12:08 PM
mtm864's Avatar
mtm864
i know this is a old thread but i have the same thing mine does the same but if i hold the rpms steady at 2000+ in neutral it sounds more like a rod knock how can i justify if its a rod knock or not?? oh and at idle it doesnt do it the car is like^^ mentioned gas light on what procedures should i take in this probblem
Old Jul 31, 2009 | 01:22 PM
vthao's Avatar
vthao
A rod knock is louder than any type of engine knock...as in low octane fuel causing the engine to knock. It's more persistent. Try listening if the sound is coming from your block.
Justin100
Nov 29, 2015 03:58 PM
Vigman
Nov 17, 2015 04:34 AM
codek
Sep 28, 2015 03:03 AM
mjgfish
Sep 22, 2015 05:55 AM
Brantwilliams13
Sep 16, 2015 05:03 AM
