car wont start!!!! need help!!!
Old Jul 30, 2008 | 04:14 PM
lay zzz's Avatar
lay zzz
Default car wont start!!!! need help!!!
so about a week ago i turned my car on and it turned on fine but there was no throttle response..so i shut the car off and turned it back on and it was good.As the last two weeks went on it did it more and more. till today. Now it wont start. It sounds like the pump isn't working but that wouldn't be in relations to the other weeks symptoms. I read somewhere here to try a reset..i need help.warranty ran out and just moved ..please tell me theres a quick fix..haha..burn it!
Old Jul 31, 2008 | 10:16 AM
lay zzz's Avatar
lay zzz
any help please!!!
Old Jul 31, 2008 | 10:28 AM
teh215's Avatar
teh215
I doubt that the reset will fix it but, you cluld give it a shot. When you say that it won't start, does it crank?
Old Jul 31, 2008 | 12:26 PM
lay zzz's Avatar
lay zzz
now it wont crank it was at first and now i tried it again and nothing. I m trying to get my car over to a shop but no luck. Does anyone think it might be a fuse??
I spoke with a buddy with an s2k and he said he's blown fuse that would let the car start
Old Jul 31, 2008 | 12:27 PM
lay zzz's Avatar
lay zzz
Old Jul 31, 2008 | 12:28 PM
lay zzz's Avatar
lay zzz
also if it means anything...two weeks ago they had to put a new ac belt and that when the problems started
Old Jul 31, 2008 | 12:31 PM
teh215's Avatar
teh215
If it no longer cranks then I would bet that it is the battery. Since it started when they replaced the AC belt, they probably didn't properly re-install the main drive belt which has to be removed to install the AC belt. Have you looked under the hood? If the belt is way loose (or missing) you may just need to belt tightened/replaced and then jump start the car.
Old Jul 31, 2008 | 01:06 PM
lay zzz's Avatar
lay zzz
yeah i tried the battery and it didnt start up with a jump. actually i did see the belt and i told the guy it didnt look really tight..i will try that next..thanks alot. Your the only response i got ..ima try this right now
Old Jul 31, 2008 | 01:08 PM
teh215's Avatar
teh215
Let me know, I'll be around for a while longer
Old Jul 31, 2008 | 01:38 PM
cbeneke's Avatar
cbeneke
Make sure that your battery connections are tight. I ran into a similar problem and it was because one of my battery connections wasn't tight.
aarrgghh
May 1, 2022 11:04 AM
Ronso
Oct 30, 2015 12:39 PM
OdesiTT
Sep 30, 2015 10:47 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
