Restoring Horsepower
Old Aug 6, 2008 | 03:25 PM
Paintballislife's Avatar
Paintballislife
Default Restoring Horsepower
So i have an '03 with 95k on it, still runs great, but where are some point i need to look at to restore power? Have a new K&N, getting a 5/16 spacer and a pop charger soon, while i have evrything apart I am going to hand clean the Throttle body, install a oil catch, new plugs and clean the upper and lower plenum assembly. Any other things i should look at?
Old Aug 6, 2008 | 03:34 PM
marques1's Avatar
marques1
you should look into buying some turbonators to restore your power!!!!
Old Aug 6, 2008 | 03:39 PM
DHCrocks's Avatar
DHCrocks
add a can of BG 44k to your gas and it'll help clean out your injectors.
do the seafoam to the intake and it'll clean the intake plenum and valves.
You should notice a smoother idle and acceleration after doing these two treatments on a high mileage engine.
Old Aug 6, 2008 | 03:42 PM
Paintballislife
I have done seafoam before, I figured since i have the plenum apart might as well clean it. Def look into the BG 44k
Old Aug 6, 2008 | 05:07 PM
MyZ4U2C's Avatar
MyZ4U2C
I think you are on the right track. This past weekend i cleaned my throttle body with Deep Creep (Seafoam) and it makes the car idle SO smooth right now. Im ready to tackle spark plugs next myself.
Old Aug 7, 2008 | 06:44 AM
Paintballislife
I gave up on that DG 44k, cant find anyone who carries it here. So I got some lucas quick tune and will try that.
Old Aug 7, 2008 | 06:49 AM
zstreet86's Avatar
zstreet86
run a can of MOA in your next oil change, and a can of 44K on your next fill up.
Old Aug 7, 2008 | 07:25 AM
Restore the horsepower? Where did it go?
Old Aug 7, 2008 | 08:54 AM
Paintballislife
ran away, needed to be free. Iz out in asz chopter looking for mahz horsez.
Old Aug 9, 2008 | 11:40 PM
LOL. I am against taking apart and cleaning anything that is working properly.
Old Aug 10, 2008 | 08:20 AM
Mazinger Z's Avatar
Mazinger Z
Oil change + 10hp.
Old Aug 10, 2008 | 09:24 AM
BlueZ33's Avatar
BlueZ33
what is this sea foam that you speak of and how do you use it
Dymsi
Sep 29, 2015 11:32 AM
torchkc
Sep 11, 2015 08:26 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
eskimo
Nitrous Oxide
282
Jan 30, 2011 03:22 PM
