Gas Light on @ Half tank
Old Aug 13, 2008 | 06:45 AM
phreaktor's Avatar
phreaktor
Design Engineer
Default Gas Light on @ Half tank
Turned the car on and DTE indicator is flashing @ 100 mile to empty and tank gauge shows empty with the light on. Turned it off and moved key back to on position and it was normal @ half tank. Started car and it went back to empty with DTE flashing.
Anyone know what this is?
Old Aug 13, 2008 | 08:07 AM
ktownogg's Avatar
ktownogg
Mine has been doing that for years. It gets worse when it is really hot out. I've gotten the low fuel light with almost 200 miles DTE. I think that it may be common, but I am lazy and just learned to live with it.
Old Aug 13, 2008 | 09:16 AM
VO...'s Avatar
VO...
Administrator
First I've heard of this problem...
Old Aug 13, 2008 | 09:17 AM
Jimmyg41's Avatar
Jimmyg41
Me too...just learned to live with it. Usually I turn off the car and turn it back on and it just works itself out.
Old Aug 13, 2008 | 09:18 AM
Jimmyg41's Avatar
Jimmyg41
I see what you did there....in other words search.
Old Aug 14, 2008 | 11:14 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Fuel pump perhaps. The DTE display and actual gauge went absolutely mental before my Z had it's fuel pump replaced. Showing empty, when you'd not long filled, flipping/changing up and down on how much til empty in a matter of 2 minutes.
Is the fuel pump a bit on the noisy side at the moment??
Old Aug 14, 2008 | 11:15 PM
black06z's Avatar
black06z
This is the 1st time Ive heard of this as well.
Old Aug 15, 2008 | 04:32 AM
phreaktor's Avatar
phreaktor
Design Engineer
I haven't noticed it at all.. I'll have a listen when I go out for break. Everyone that is saying it's nothing- Major electrical problems often manifest themselves in the form of seemingly harmless symptoms.
Old Aug 15, 2008 | 06:21 AM
jak24lp's Avatar
jak24lp
My car does this to. I have a 06 enthusiast. I took it to my local Nissan dealership. They kept it for 3 weeks. They replaced the fuel pumps, fuel sensor, guage cluster, and even took panels off the car to see the wiring. Guess what they found? Nothing. They spent hours on the phone with corporate Nissan and couldn't come up with why my car does this. Nissan finally says that its a common problem and that all Z's do this. I have a hard time with this answer but thats what they told me.
Old Aug 15, 2008 | 06:23 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
If it is the fuel pump, it will start getting quite noisy, really shrill, and it will be uncomfortable to be in the car, sore ears + the giving all sorts of crazy false readings on the displays. When went through this with my Z, it was probably 3 times as noisy as what is considered to be normal. Very audible even with the radio on.
Fuel pump was replaced, the problem went completely, and the replaced pump makes almost no noise, even without the radio on, that's how quiet it is now.
Perhaps do what I did, get quite a few Z's together, and listen and see what is normal, you'll soon pick it, if your Z is way louder. If yours is still under warranty take it to dealer and do the same, this is what I did to prove the point. They do have readers, but proving what isn't normal makes it harder for dealer to argue the point.
It was harmonic vibrations in my Z that took the fuel pump out, all ok in that aspect with your Z Phreaktor?
Old Aug 15, 2008 | 06:39 PM
haeshik's Avatar
haeshik
wth?
Old Aug 15, 2008 | 09:09 PM
04LIQUIDSILVER's Avatar
04LIQUIDSILVER
Mine does the same **** all the time I put fuel every chance that I got ... (ran aut of fuel once )
Old Aug 18, 2008 | 09:23 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Any resolve yet Phreaktor?
Old Aug 25, 2008 | 07:25 AM
350zinallday's Avatar
350zinallday
This happens all the time to me, I just put gas in around 275miles just to be safe. My fuel pump isn't making any noises, but I thought it was the fuel sensors and the dealership wanted to tear up the trunk to get to the tank and since I have a custom system in it, I was in no hurry to let them do it; so I said screw it.
Old Sep 6, 2008 | 09:05 PM
deezz's Avatar
deezz
Yeah...My gas gauge has a mind of it's own. I just ran out of gas tonight. I put $40 in before and the damn thing just went to 1/4 of a tank. Out of warranty, so I will just have to live with it and keep gas in it on the regular.
Old Oct 26, 2008 | 07:36 PM
zracin's Avatar
zracin
I know im hopping in on an old thread,but no need to start a new thread. what did it cost you to replace fuel pump?
Old Oct 26, 2008 | 09:54 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Zracin, my Z's was done a couple or so years ago, under warranty, Kiwi's dollars, so price of parts is a bit different in US.
Old Dec 5, 2008 | 12:11 AM
itburns's Avatar
itburns
This started to my Z (101,000 miles) just a few days ago! It's obviously not heat-related as this is winter time in Nor Cal. It's very disconcerting because even though I'm sure I have 1/2 a tank left, I don't want to "chance it" so I stop to fill it up anyway (usually 7-8 gallons). I'm afraid if I get into the habit of disregarding the fuel guage I might lose track of what I really have and then run out of gas one day.
I don't want to take it into the dealership and spend hundreds of $$$ only to have them find nothing wrong!
I'm curious what your mileage is....
Old Dec 5, 2008 | 10:13 AM
BRONZEE's Avatar
BRONZEE
Club Moderator
Is your fuel pump excessively noisy? When my fuel pump started to give out, it started getting very noisy, ie, extremely shrill and it would hurt my ears to be in the car. The noise will give you some indication as to the state of the pump. Any dealer should be able to hear that, do a comparison to a few others if you're not sure.
Old Sep 7, 2010 | 03:01 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Bump asap my friends car had vacuum leaks and wouldn't rev pass 4-5k took it the dealership and they fixed the leaks they say now they say it's the fuel pump that's preventing his car from accelerating!
Help they talking about $2300 when it's all said and done
Any help is appreciated
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
ablaine
Nov 29, 2016 10:13 AM
350z82
Oct 1, 2015 06:25 PM
