Slip light,tcs, and ses on when dynoed
Old Sep 6, 2008 | 05:00 PM
alltel350z's Avatar
alltel350z
Default Slip light,tcs, and ses on when dynoed
I have tried to search but found a lot of dead ends. I just got a aps st kit installed and when getting it tuned on the dyno after 4 pulls the lights came on and no trottle response now. I read on anouther post that this problem destroyed a utec which is what I have and hope this does not happen. This is the first and only time this has happend.
Old Sep 7, 2008 | 03:15 PM
Cide's Avatar
Cide
do u have the DTC number?... i left my Z sitting for about 3 weeks at one point and when i drove it the next time everything was fine but out of nowere the check engine, tcs, and slip came on. the car idleled perfectly but didnt have any throttle response. i have a code reader so i hooked it up and i got a code that was manufacturer specific but i looked it up online and it turns out it was something with the throttle. so what i did was disconnect the throttle and got me a electronic contact cleaner and some electric grease and cleaned it and pluged it back in reset the pcm and it was good to go.. u can reset it by disconnecting the battery for about 30 min in case u didnt know...good luck man let me know if it helped.
Old Sep 18, 2008 | 07:49 PM
alltel350z's Avatar
alltel350z
got a used tb and a new tb. the only way they work is if we run the car on the stock ecu. and ideas?
Old Sep 18, 2008 | 10:42 PM
ADMAN's Avatar
ADMAN
Oh, you mean like this???
Did you throw a P0335 code or something else???
Old Sep 20, 2008 | 10:52 AM
alltel350z's Avatar
alltel350z
Angry
I don't rem the code but it was a etc code (electronic throttle control). how would this effect the utec? I just bought another one.
Old Oct 29, 2008 | 07:58 PM
alltel350z's Avatar
alltel350z
the code was p1122. got another utec and the same crap happend again. after about an hour or two and 350whp it went out again. wtf is causing this?
Old Oct 30, 2008 | 03:37 AM
ChrisR's Avatar
ChrisR
thats how mne looks when i turn the car on....sometimes only the SES light comes on but when i floor it they all go on...it all started after the nitrous was installed
Old Oct 30, 2008 | 07:03 AM
alltel350z's Avatar
alltel350z
did you ever find the problem?
Old Oct 30, 2008 | 09:35 AM
ChrisR's Avatar
ChrisR
i would like to know!
Old Oct 30, 2008 | 12:07 PM
ADMAN's Avatar
ADMAN
Well, mine went away after I replaced my CPS. That is the code I got.
However, you're throwing a different code. You said yours was:
P1122 Electronic Throttle Control Actuator
Sorry. Doesn't look to be the same problem.
Old Oct 30, 2008 | 06:28 PM
alltel350z's Avatar
alltel350z
Unhappy
The first tb was ruined so was the utec. Got a used 06 tb from a friend that worked fine with no utec and then got the new utec, a hour later the car will not rev with or wo the utec.he said it was giving a drivetrain code. He believes it is something to do with the traction control causing the issues and says he wants to disable it. Any tips on what to do next?
Old Nov 5, 2008 | 08:38 PM
alltel350z's Avatar
alltel350z
Well bought a new tb, and the same results. Revs with no utec but won't rev with utec. All the pins in the harness????
Old Jan 21, 2009 | 09:49 PM
NISMOFO's Avatar
NISMOFO
These are the 3 lights I have right now. throttle response feels mushy...lagging kind of like an automatic.
Old Jan 30, 2009 | 08:34 PM
alltel350z's Avatar
alltel350z
Unhappy
The car is @ forged performance now. I sure hope its something small when they find the problem. So far the shop that did the install couldn't fine the issue nor nissan. My fingers are crossed.
Old Feb 21, 2009 | 02:12 PM
tylerxfire's Avatar
tylerxfire
??? so...
Old Feb 26, 2009 | 07:43 PM
alltel350z's Avatar
alltel350z
Originally Posted by tylerxfire
??? so...
No news yet. I think they are trying to finish up another car before they start on mine again. I just hope it is something small. Can't wait to post the problem when I know what it is. I have had the wrost time with this. Should have left it stock.
Old May 5, 2009 | 04:52 AM
alltel350z's Avatar
alltel350z
The problem was that the engie harness was resting on the exhaust manifold. Forged replaced it now it works.
Old May 5, 2009 | 08:40 AM
zippy75's Avatar
zippy75
reason bcos worn brake pads or low brake fluid..
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
