Replacing Front Wheel Stud
Old Sep 30, 2008 | 09:56 AM
JETPILOT's Avatar
JETPILOT
Default Replacing Front Wheel Stud
Does the hub have to be taken apart or can you knock them out and replace them with just the brake removed and hub intact.
Old Sep 30, 2008 | 10:11 AM
35oZephyR's Avatar
35oZephyR
Rubber mallet...take off caliper, hammer out the brake rotor.
Hammer out the old stud, slip in the new one.
Some washers or open ended lugnut to tighten on the new stud and you're done. No hub removal whatsoever.
Old Sep 30, 2008 | 10:15 AM
Crom's Avatar
Crom
hammer time...
Old Sep 30, 2008 | 10:08 PM
rr_z33's Avatar
rr_z33
i actually have the entire front wheel hub assembly with wheel studs if you want to buy it. i just need to get rid of it. it costed 215 from forged performance. so make me an offer if your interested.
Old Oct 1, 2008 | 02:32 AM
Triple8Sol's Avatar
Triple8Sol
Like they mentioned, no hub dis-assembly required.
Old Oct 1, 2008 | 03:05 AM
terrasmak's Avatar
Remove caliper , remove caliper bracket , remove rotor, 5 pound sledge to the bad stud, slide new stud in place , install rotor and caliper, install 4 flat washers and open ended lug(flat side in, basically backwards ), have someone hold brakes, crank lug till tight, look at backside on hub to make sure the stud is pulled flush, and install wheel.
If you have one bad stud, i suggest buying a set of NISMO extended studs with proper lugs since you track your car.
Old Jul 15, 2012 | 05:10 PM
ALO8's Avatar
ALO8
if i press in studs with washers and a lugnut, the hub keeps spinning while i torque, do i have to slap on rotors and brakes to stop hub from spinning?
Old Jul 15, 2012 | 05:11 PM
terrasmak's Avatar
Makes it easier
Old Jul 15, 2012 | 06:27 PM
ALO8's Avatar
ALO8
Is it true I can only use the lug nut once to press one stud? After that it goes to waste?
Old Jul 15, 2012 | 10:17 PM
GGGVenom's Avatar
GGGVenom
Alot easier with a air impact wrench ..
Old Jul 15, 2012 | 11:14 PM
ALO8's Avatar
ALO8
yes because if i slap the rotor on i cant see if the stud is seated i would have to remove rotor and check. i dont want to use the impact with my luck ill strip the threads. Im going to try with a ball joint separator method.
seagrasser
Oct 11, 2015 03:27 PM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
RWDBajan
Sep 17, 2015 04:52 PM
Beater350z
Sep 9, 2015 03:36 PM
