VDC SLIP and SES light on? sometimes BRAKE comes on
Old Nov 2, 2008 | 06:12 PM
ChrisR's Avatar
ChrisR
Default VDC SLIP and SES light on? sometimes BRAKE comes on
well i went to autozone and got the codes that my car is throwing....
p0102 MAF SENSOR
p0113 IAT high output
there was another one i had it written down but can not find it, it was a code for air fuel meter.
i currently have a spacer intake and exhaust installed and im guessing it is running lean or rich (for the air fuel meter code to go off?). on the obdII reader it says the p0102 and air fuel code are pending. What does that mean? and as far as the p0113 im guessing the intake air temperature is too hot, how do i fix that?
Old Nov 2, 2008 | 10:32 PM
ADMAN's Avatar
ADMAN
Reset ECU. See if it comes back.
VDC,SLIP & SES = P0335???
Old Nov 3, 2008 | 07:29 AM
ChrisR's Avatar
ChrisR
i think the two that are pending will go away once i get the car tuned.... im going to try to go to the dyno this week to get the A/F reading im sure its nowhere close to where ti should be to cause the air fuel meter code to go off. im worried about installing my TPs for now.
Old Nov 3, 2008 | 11:46 AM
cliffordrican's Avatar
cliffordrican
i hit a bump and those lights came on brake vdc and slip and stayed on ???
Old Nov 4, 2008 | 10:01 AM
ChrisR's Avatar
ChrisR
helpp
lol
Old Nov 4, 2008 | 03:23 PM
z2g's Avatar
z2g
Check brake fluid level?
Old Nov 11, 2008 | 11:47 AM
ErkTheJerk73's Avatar
ErkTheJerk73
+1
then check your pad/rotor wear
Old Jan 21, 2009 | 09:45 PM
NISMOFO's Avatar
NISMOFO
this is what I have...all three lights. Any suggestions on the fix?
Old Jan 21, 2009 | 10:13 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Make sure your brake fluid is at the appropriate level and check your pads (if brake fluid is low) first.
If nothing, continue reading.
Directly from the Service Manual
P0102 & P0103
P0112 & P0113
P0335
EC137
Let me know if you need any of the pages not given above (underlined and in green in above pics) and I will provide copies of those also.
Old Jan 22, 2009 | 10:06 AM
NISMOFO's Avatar
NISMOFO
I disconnected by battery over night and the lights went away (for now). But I think its the electronic throttle control. I think it needs to be cleaned?
Old Jan 22, 2009 | 10:14 AM
3hree5ive0ero
Retired Admin
From what I understand, disconnecting the battery over night does nothing, as there's probably another battery or a power source for the ECU. If it did do something, then every time the battery died, it'd reset everything all the time. I'd go through the troubleshooting process just in case.
Old Jan 25, 2009 | 08:26 AM
NISMOFO's Avatar
NISMOFO
Update: My issue was a code P0340 which was the Crankshaft Position Sensor. Dealership replaced it and did a reflash, but I had to pay out of pocket.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
