SES Light On
Old Nov 10, 2008 | 05:26 PM
na_350z's Avatar
na_350z
Default SES Light On
I've read a few threads but I have a specific question. I have the Berk HFC's with Tanabe Y-Pipe & Tanabe Hyper Medallion exhaust. Never had a problem with the SES light coming on. I've had this set-up for about 8 months now. So just the other day I got a SES light. So I took it to the dealer and they ran the diagnostics and said they needed to replace the Air Fuel Ratio Sensor. The actual part number is 22693-CD700 Heated Oxy which is the Oxygen Sensor correct? Everything came out to 329.61 including labor. So two days go by and again with the SES light. It came on again and now I'm wondering are they messing with me or what are the chances that both oxygen sensors need to be replaced if i'm correct when they say Air Fuel Ratio Sensor is actually the oxygen sensor.
Old Nov 10, 2008 | 08:31 PM
The heated oxygen sensor sends a voltage signal to the ECU. The ECU adjusts injector pulse duration to alter the air-fuel ratio. Not aware of a part called “Air Fuel Ratio Sensor.”
Old Nov 11, 2008 | 08:39 AM
na_350z's Avatar
na_350z
Originally Posted by davidv
The heated oxygen sensor sends a voltage signal to the ECU. The ECU adjust injector pulse duration to alter the air-fuel ratio. Not aware of a part called “Air Fuel Ratio Sensor.”
That's the thing that I don't know what the Air Fuel Ratio Sensor is. I disconnected the battery to clear the code which is off for right now. I'm hoping it doesn't come back on but only time will tell. I'm hoping someone knows what the Air Fuel Ratio Sensor is.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
