dome light help
Old Apr 21, 2009 | 05:17 PM
03350ztrack23's Avatar
03350ztrack23
Default dome light help
My dome light wont work. I checked the fuse and the bulbs and both are good. The gauge pods work fine. Anybody else have this problem and able to fix it?
Old Apr 21, 2009 | 05:29 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
There's a way to reset that and get it to work again. I'll send you a PM.
Old Apr 21, 2009 | 06:02 PM
03350ztrack23
I fixed it. Thanks for the help
Old May 14, 2009 | 12:56 PM
emerlin's Avatar
emerlin
i have the same problem? Can someone help me? I checked the fuses, bulbs, and even tried testing the 3 wires connected to the light. no power.
Old Jun 8, 2009 | 03:09 PM
binder's Avatar
binder
is there a fuse? i don't see a label for it in the kick panel or the engine. Everything works but my dome lights and the lights under the doors.
Just stopped working recently.
Old Sep 20, 2011 | 06:43 PM
White0ngold's Avatar
White0ngold
same question, same problem
Old Sep 20, 2011 | 08:15 PM
winchman's Avatar
winchman
Yeah, but the answer was in a PM to the OP.
Did you check the door/off switch between the lights?
Old Sep 21, 2011 | 08:19 PM
White0ngold
yea, I did. I disconnected the unit n connected back and still nothing, i switch the bulbs and still nothing, I'm not the sure which one is the Fuse for the dome lights though would it be the "Room Lamp"?
Old Sep 21, 2011 | 08:46 PM
winchman's Avatar
winchman
Looking at the '07 service manual, it's not really clear if there is a separate fuse for the interior room light.
In section BCS, it looks like the power comes from the Body Control Module. If other stuff controlled by the BCM is working, the problem is there or in the wiring. The other stuff includes the keyless entry, power door locks, power windows, and power seats.
In section PG, it shows 10A fuse #21 on fuse block (J/B) providing power to those.
The SM for your year may show something different.
Old Sep 21, 2011 | 11:39 PM
White0ngold
well the windows and door locks work, i dont have power seat, and my car is an 04' , where is "section PG" and which fuse block are u talking about, i know our cars have 3 Fuse boxes, the kick panel and the two by the battery..
Old Sep 22, 2011 | 02:55 AM
Fitzys350z's Avatar
Fitzys350z
quite simply just unplug the neg on the battery for a few min and this will fix the problem. I had the same problem and resetting the ECU fixed it.
Old Dec 28, 2022 | 03:10 PM
pyty's Avatar
pyty
please i need help for this issue. I change BCM and works but change to leds and again don´t work. I don´t see any info but other people have pdf for repair. Please can hekp me and future issues? thanks
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
