Severe engine braking, when off the gas pedal
Old Apr 23, 2009 | 08:41 PM
donkinuts's Avatar
donkinuts
Question Severe engine braking, when off the gas pedal
Greetings. By the way, I have a 2008 6sp. I notice that when in gear and letting off the gas pedal, the "engine braking" is severe. It doesn't really matter which gear I am in, the car just wants to slow down if I am not pressing on the accelerator.
As you can probably imagine, the transitions from "on gas pedal" to "off gas pedal" is not smooth. The engine seems to rev freely for a split second, then the engine breaking occurs.
Old Apr 23, 2009 | 08:55 PM
zettahertz's Avatar
zettahertz
is this your first manual car or something? Engine braking is much more pronounced in manuals. And there's a lot of engine braking in the lower gears. and less towards 5th and 6th.
Old Apr 23, 2009 | 09:46 PM
04zee's Avatar
04zee
It's
Normal
Old Apr 23, 2009 | 10:03 PM
Spork's Avatar
Spork
How old are you?
Old Apr 24, 2009 | 01:01 AM
Gibbs's Avatar
Gibbs
Know it all
If your revs are high it will be more noticable than at lower revs.
Old Apr 24, 2009 | 01:33 AM
quiksilverx181's Avatar
quiksilverx181
Originally Posted by Spork
How old are you?
It seems like every third thread i visit, i see at least one person ask this. Now my question is, why does it matter? Just curious.
Old Apr 24, 2009 | 05:09 AM
donkinuts's Avatar
donkinuts
I am 31 and been driving manual cars for 10+ years. What I am trying to say is, that it is severe compared to other cars I've driven / owned. There is almost no ability to "coast" at a steady speed. The gears in this car feels like "a rubber band that wants to retract almost immediately if let go." I just noticed is was more pronounced that any of the manual cars I've driven. If this is considered normal for the Z's, then all is good.
Old Apr 24, 2009 | 05:25 AM
Tac-M's Avatar
Tac-M
simple answer - high compression engine.
also, that is a good thing, saves brake pads.
Old Apr 24, 2009 | 06:32 AM
cheshirecat79's Avatar
cheshirecat79
Exactly.
Out of the manuals I've owned, the Z has the worst (best?) engine braking. I use it all the time.
It's normal. Get used to it.
Old Apr 24, 2009 | 06:48 AM
Better have it checked out. Sounds like you need a new transmission. Its covered under warranty.
Old Apr 24, 2009 | 08:27 AM
Spork's Avatar
Spork
It can reflect his experience and knowledge with cars.
Like mentioned, it's part of having a higher compression engine. Doesn't hurt anything, jst gotta get used to it. Comes in handy for downhill roads, so you don't have to ride the brakes.
liqalu04
Jan 2, 2022 12:58 PM
samansharif
Sep 25, 2015 12:31 PM
