Idle RPM
Old May 30, 2009 | 02:20 PM
payam404's Avatar
payam404
Default Idle RPM
Hi guys.
i replaced my spark plugs yesterday. my idle RPM use to be 500 but now i have 1000 RPM. i did reset ECU (unhooked the negative side of battery for about one hour).
new spark plugs are Iridium IX and old ones where OEM.
any idea? or should i be worry?
2005 350Z Stock
Old May 30, 2009 | 02:48 PM
tanabe350z's Avatar
tanabe350z
is that an idle when your engine is warm or when it is cold, if its warm that something is wrong, but if its cold than its perfectly normal
Old May 30, 2009 | 03:05 PM
dragonfire6's Avatar
dragonfire6
Default ...
idle should be 650 (+- 50) says the service manual after ur car warms up
Old May 30, 2009 | 05:22 PM
payam404's Avatar
payam404
it is when is warm. idle actually is 1200 RPM right now, and the exhaust gas smells really bad.
when i was replacing spark plugs yesterday, i also cleaned inside throttle with carburetor cleaner.
is it possible that damaged something? oh, and i toke it to advance auto part(because check engine light is on) and computer said high idle speed.
Old May 30, 2009 | 05:29 PM
tanabe350z's Avatar
tanabe350z
reset your ecu via the pedal ignition trick then see how it acts, if its still a problem take it to nissan
Old May 30, 2009 | 07:02 PM
payam404's Avatar
payam404
Thumbs up
O.K
i just fixed it!!!
it was my mistake. when i was reinstalling the throttle, i put the brass gate upside down.
anyway, i just wanted to let you know what was the problem.
thank you for your responses.
Old May 31, 2009 | 12:52 PM
tanabe350z's Avatar
tanabe350z
lol that tricky throttle body, glad to hear its fixed
Old Jun 1, 2009 | 11:31 AM
karolin768's Avatar
karolin768
Arrow you will need these later
Once you are wearing the ivory wedding dress, it's best to avoid the lace wedding dress applying makeup. If you need to, do so carefully. And if makeup, wine or any other substance stains your modest wedding dresses on the day, you will need to seek advice about the designer wedding dress
liqalu04
Jan 2, 2022 12:58 PM
pslamp32
Feb 8, 2017 09:07 AM
Justin100
Nov 29, 2015 03:58 PM
Inspatatrac
Sep 8, 2015 02:12 PM
