HELP!! Car shakes at 2000 RPM!! HELP
Old Jun 4, 2009 | 08:47 AM
PrOjEcT ZeE's Avatar
PrOjEcT ZeE
Default HELP!! Car shakes at 2000 RPM!! HELP
Can someone please help me, K when I'm in neutral I REV the engine up to like 5000 everything is fine, but when it drops to like around 2000 to 1500 the car shakes, then it drops down to 500 with no problem. I repeat this process a couple of times and still the same thing happens. What should i do?
I have only bolt on parts. Someone please help!!!
Old Jun 4, 2009 | 10:13 AM
cheshirecat79's Avatar
cheshirecat79
500 is a tad low for the idle. Are you sure you don't have a vacuum leak with your "bolt on" parts? Is a plenum spacer involved?
Old Jun 4, 2009 | 10:26 AM
importdemon5's Avatar
importdemon5
Is there any sound when it shakes? Is it a vibrating shake or is it a legit shake?
Old Jun 4, 2009 | 10:28 AM
Nexx's Avatar
Nexx
swine flu!
Old Jun 4, 2009 | 11:08 AM
PrOjEcT ZeE
yes i have a 1/2" MD spacer. but when i plugged in the OBD2 it say 650 700
Old Jun 4, 2009 | 11:10 AM
PrOjEcT ZeE
It's a vibration shake. like it want to die out/
batousai's Avatar
batousai
I dunno that much about cars. But from what it sounds like, is the tachometer needle bouncing up and down and down and then the rpm drops causing the car to shudder?!
My buddy's old mustang had that problem and it was a cracked head gasket and possibly a bad spark plug causing misfiring or something to that order. Get it diagnosed..
Old Jun 4, 2009 | 11:16 AM
PrOjEcT ZeE
no it doesn't fluctuate like that, it just vibrate
Old Jun 4, 2009 | 11:20 AM
PrOjEcT ZeE
swine flu!
have any idea what's wrong with my car?
Old Jun 4, 2009 | 11:26 AM
PrOjEcT ZeE
Can someone please tell me what it is.
Old Jun 4, 2009 | 11:27 AM
JasonZ-YA's Avatar
JasonZ-YA
^ lol...
Old Jun 4, 2009 | 11:28 AM
JasonZ-YA's Avatar
JasonZ-YA
i would check all around the plenum and your bolt ons......listen for any leaks, have someone else do the reving you were doing and listen for the defect.
if not, take the car in and have them check it out.
no engine light/codes yet?
-J
Old Jun 4, 2009 | 11:41 AM
PrOjEcT ZeE
me and my friend just did that this morning. (with the car warmed up) i hear no leaks. i though it might be the air sensor. cause i did over oil the pop-charger and ran it for like 500 miles. then replace it with a brand new one. I'm getting 19 MPG now on the freeway don't know about local.
Old Jun 4, 2009 | 11:48 AM
JasonZ-YA's Avatar
JasonZ-YA
humm>?? i doubt its MAF related since its only doing it at certain rpms...........
Old Jun 4, 2009 | 12:45 PM
Nexx's Avatar
Nexx
warranty, do you haz?
Old Jun 4, 2009 | 02:12 PM
PrOjEcT ZeE
nope, just expired it's an 03 with 30K on it. i don't drive it a lot i have a FD and a s2k i drive mostly the s2k as a DD
Old Jun 4, 2009 | 02:16 PM
PrOjEcT ZeE
Can anyone one else help me? don't want to go to the dealer they want 190 to diagnose it. i think that's a rip off.
Old Jun 4, 2009 | 03:18 PM
ag4670's Avatar
ag4670
lol i just posted this in another thread
i hade a similar problem but mine was acting like it was going to die, this might help some people not everyone. i jacked the car up disconnected the o2 sensor after the cat just the green one passenger side and started my car up and the problem went away i never had the problem again. in my case with no tune running headers/exhaust and etc my car is running too lean killing my 02 sensors hopefully this helps someone
Old Jun 4, 2009 | 03:19 PM
ag4670's Avatar
ag4670
try the ecu reset too
http://www.technosquareinc.com/350reset.htm
Old Jun 5, 2009 | 04:17 AM
That One Dude's Avatar
That One Dude
I think I know what you’re talking about... Are you talking about as you are decelerating or accelerating slowly in a specific gear that it happens to cross the 2000-2300 - 1700(Maybe not this low) RPM area and begins to receive a awkward and pronounced vibration through the car... i.e. Steering Wheel, Shifter, perhaps maybe the clutch pedal and other pedals..?
I wonder what it is... if that is the "Shake" or "Vibration" that you are talking about.. Could it be perfectly "normal" like the loud throw out bearing or crazy clutch that these cars have?
I have wondered about this... Could it be a mechanical issue? Maybe we need to get some of those "Engine Stabilizer" mechanisms in order to avoid the shake of the engine or drive train..? This is only a suggestion...
Does anyone experience this atrocity?
As a reference, I have a 2008 Base…
