ramps for oil change
Old Aug 11, 2009 | 05:44 PM
cachinbombete's Avatar
cachinbombete
Default ramps for oil change
How many ramps do i need to do my oil change. Does the car has to be leveled ( with 4 ramps) or can i put ramps only on the front.
Thanks for all the previous help, but i was not sure
Old Aug 11, 2009 | 06:05 PM
s31t8n8's Avatar
s31t8n8
just drive one side of the front onto the curb
Old Aug 11, 2009 | 06:26 PM
AznSky's Avatar
AznSky
I usually like to have the car level so it drains well and not all over the place either.
So I usually drive the front onto ramps, and lift the rear with a floor jack at the differential (cuz rear is a lot easier to access)
Old Aug 11, 2009 | 07:37 PM
cachinbombete
Is the differential strong enough for the floor jack (differential material is aluminum based isn' it). Also, the differential bottom is kinda round
Old Aug 11, 2009 | 09:32 PM
scotts300's Avatar
scotts300
Yes.
scotts300's Avatar
scotts300
Funny. That's exactly how I used to do it when I lived in Piscataway and did not have a garage with a bunch of tools.
Old Aug 12, 2009 | 10:28 AM
zettahertz's Avatar
zettahertz
decided to try this interesting thing out for the oil change:
http://www.qwikvalve.com/home.php
Should simplify the process and minimize the mess. Anyone else got this?
Old Aug 12, 2009 | 12:34 PM
scotts300's Avatar
scotts300
Cool, and it would pay for itself in about 20 oil changes! I may pick one up for our ZR, which is a DD.
Old Aug 12, 2009 | 02:28 PM
WhiteNoiz's Avatar
WhiteNoiz
Sounds like extra unnessesary work if you ask me. Next time your under the car look at the design of the oil pan. Lifting the front actually helps the oil pan drain. If you were to lift the front, and then lift the front drivers side slightly more, it would drain even better/the best. Keeping the car level will not help the oil drain out. Having the car level is only important in filling the tranny and differential with fluid, and checking the oil once filled. Secondly, I dont see how having the car level would or would not prevent a mess
Old Aug 12, 2009 | 02:32 PM
WhiteNoiz's Avatar
WhiteNoiz
Please post vid of you driving up onto four ramps
Old Aug 25, 2009 | 10:30 AM
JasonZ-YA's Avatar
JasonZ-YA
You already made this thread: https://my350z.com/forum/maintenance...s-or-ramp.html
You only need onethread on a particular subject sir. and please read the link posted on post #4 on that thread.
/thread....
-J
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
