WTF "Slip" & "VDC" & "Brake" light
Old Aug 18, 2009 | 12:42 PM
Globalscan's Avatar
Globalscan
Default WTF "Slip" & "VDC" & "Brake" light
I have a 2005 Grand Touring Roadster. In the last few weeks the slip, VDC, and brake light have been popping on. It started a while ago but only did it a few times. Now it seems to do it all the time.
It is mostly when during acceleration?
Anyone else having/had this issue? If so, what was the outcome?
Old Aug 18, 2009 | 12:50 PM
topcity350z's Avatar
topcity350z
as far as brake light, check your fluid level, i had a problem with mine coming on, added fluid and went off. as far as the other 2 i havent herd of anything coming on cause of that, maybe your tires are slipping during accel? or a sensor could be bad, or possibly somthing in your drive train is slipping when you accel.. just throwing ideas out there.. also i had put different rims and tires on my nissan titan and the slip and brake lights just come on and go off as they please, just learned to ignore it. maybe put your stocks back on and see if it stops.
that all my knowledge as a hobby mechanic that i have to offer. hopfully somthing helps
Andrew
Old Aug 18, 2009 | 12:51 PM
Russ@Z1's Avatar
Russ@Z1
Searching would have yielded you a faster response.
If it does it during acceleration, it could be a bad sensor or low brake fluid.
I just replaced the brake light switch in my Z as pressing the brakes triggered an error from the switch and caused the lights to activate. ($35 fix)
The code I got from reading the ecu (abs system) stated that it was the pressure switch on the abs control unit even though the switch itself was the culprit.
Old Aug 18, 2009 | 01:54 PM
DavesZ#3's Avatar
DavesZ#3
Sounds like low fluid - when you accelerate, the fluid sloshes to the back of the reservoir. That triggers the low fluid switch and it in turn triggers the lights.
Old Aug 18, 2009 | 02:20 PM
somebody's Avatar
somebody
low fluid and/or thin pads....same thing happened to me.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
