Grinding Noise At Start Up
Old May 22, 2005 | 06:05 PM
Netko350Z's Avatar
Netko350Z
Well took my Z in and "typical" answer from the service dept....
"We could not replicate the sound you described"
B.S.x10!!
So now my plan is to put my Z up on a lift and check it out myself. Also carry a video camera to capture the sound.
Old Jun 21, 2005 | 11:52 AM
eraz3r's Avatar
eraz3r
how high does everyones z rev up to on start up? Mine hits 2250 and thats when the rattle pops up. To me that seems excessive, 2k should be enough.
Old Jun 23, 2005 | 05:26 PM
Netko350Z's Avatar
Netko350Z
Well, mine was a simple exhaust rattle. My Borla was hitting the cross brace behind the tranny.
repositioned the pipes...noise gone!!
Old Jun 25, 2005 | 06:48 PM
enhanced250's Avatar
enhanced250
i got rid of my rattle too...i got rid of the car
loved the car but way too many headaches good luck to all the others!!!!
Old Jun 26, 2005 | 07:30 AM
HokieZ's Avatar
HokieZ
Have the same problem. If I leave it for several days (overnight isn't enough) I get a momentary grind noise when it starts. Fortunately I drive it almost daily so it's not a big deal
Old Jun 26, 2005 | 08:02 AM
Nano's Avatar
Nano
I have the same rattle noise. Does it only when cold and car has been sitting.
Sometime it barely does it and is almost inaudible, but sometime it's louder and clankier. It happens around 1/2 a second after the ignition is turned and last for less than 1 second.
A lot of people seem to have it.
Old May 24, 2006 | 10:18 AM
tkachuk450's Avatar
tkachuk450
does anybody have repair this problem thank you
Old Oct 2, 2006 | 09:44 PM
cnynracer1's Avatar
cnynracer1
I think this is due to using aftermarket oil filters that do not have the OEM drain back valve.
I started experiencing this problem when I switched to an aftermarket filter. I am switching back to OEM next oil change!
Old Oct 3, 2006 | 12:57 AM
Eazzy's Avatar
Eazzy
If u have a grinding noice for a sec on startup and u are sure it is comeing from that area----Whats happening is ur starter is hanging up---It may very well not do it on a bench test.
Pull it,take it to a reputable starter/alternator repair place or just spin ur drive gear out by hand and see if it is smooth.
Most importantly chk ur flywheel ring gear. It should really show no wear or have any bright shiny spots on it.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
