Transmission Leaking!!!
Old Nov 2, 2009 | 11:30 AM
brandon3434's Avatar
brandon3434
Default Transmission Leaking!!!
Hey guys,
I was installing my nismo exhaust and sway bars the other night and noticed that my transmission was wet on the bottom, looked closer and it was leaking!...Does anyone know why this could be? I'm assuming I need to get this checked out ASAP, but if anyone had this issue before, any info would be great...
Thanks!
Old Nov 2, 2009 | 01:06 PM
quietkilla6's Avatar
quietkilla6
theres 10000000000000000000 reasons it could be leaking.
go to the mech.
Old Nov 2, 2009 | 02:34 PM
DavesZ#3's Avatar
DavesZ#3
You didn't even mention if it was an AT or a MT. How do you expect an intelligent guess as to where the problem lies.
Old Nov 2, 2009 | 02:50 PM
mclovin.too's Avatar
mclovin.too
Was it around the drain plug?
Yeah it is AT or MT?
Old Nov 2, 2009 | 03:03 PM
jray8's Avatar
jray8
check the breather hose on top of the transmission, took me a 3 months to figure out where the hell my leak was coming from. it was overfilled by 1 1/2 quarts and would only leak when started under 30 degrees outside.
Old Nov 3, 2009 | 01:08 AM
brandon3434
my bad, its a manual...
and yea, this is the first year ive had my z, and it just started when it got cold...but i check every morning and there is a very small puddle where it leaked...is this the clutch fluid? sorry this is all confusing to me...
Old Nov 3, 2009 | 03:12 PM
brandon3434
anyone?
Old Nov 5, 2009 | 06:48 AM
Exodus751's Avatar
Exodus751
take a good pic if you can i mean it could be anything seal drain plug hoses you know? might not even be trans fluid after all trace it and see where it's leaking from
Old Nov 5, 2009 | 01:49 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
dude just take it to a mechanic if your unsure.
Old Nov 5, 2009 | 02:53 PM
jray8's Avatar
jray8
the only way to see if its the transmission breather hose is to start it when its under 30 degrees out and watch and see if it comes pouring out of the top of the transmission(you will need a flashlight). if its only doing it while its cold(as mine did) then im almost positive thats the problem. Z transmissions are notorious for being noisy and i believe they overfilled the transmission to try and quiet it before selling it.
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Twenty4
Jan 17, 2016 01:20 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
