Nissan dealership sent me home with this...
Old Jan 30, 2010 | 07:52 PM
coreisntlife's Avatar
coreisntlife
Default Nissan dealership sent me home with this...
I go to my local nissan dealership trying to get some nissan tranny fluid to flush my trans. They sent me home with 3 quarts of "shell spirax ew(extended warranty) gear oil" 75w-90. Apparently the mechanics there always change tranny fluid with this stuff. But it says its made for big rig differentials. Is this what i should have? 3 quarts? Dont tell me to get redline.
Old Jan 30, 2010 | 08:55 PM
92K1500's Avatar
92K1500
Do you have an automatic or a manual trans?
And yes, big rigs use 75-90wt in their axles. They only use 50wt in the trans though.
Old Jan 30, 2010 | 09:02 PM
coreisntlife
oh sorry, i should fill out my sig.
i have a 6mt, 04 z
Old Jan 30, 2010 | 09:03 PM
API GL-4 is suitable for the manual transmission. Capacity 3 1/8 quarts.
Old Jan 30, 2010 | 09:07 PM
coreisntlife
It says on the bottle, "Meets API GL-5 & MT-1 specifications"
Old Jan 31, 2010 | 07:06 AM
raycs7's Avatar
raycs7
From 350ztech
Warning!!
Do not use GL5 transmission fluid. It will damage the synchros in the Nissan transmission. You need GL4 fluid. Most fluid you buy at autoparts stores is GL5.
Quote
What is the deal with GL4/5 oil?
I thought i might add to this, after much reading.
GL4 (additive package 4) contains anti rust agents. GL5 (additive package 5) contains demulsification agents.
The demulsification agents in GL5 spec oil are known to cause premature corrosion of yellow metals ie:- brass, which i believe are used in the 350z Transmission.
Old Jan 31, 2010 | 07:51 AM
coreisntlife
wow. the nissan dealership is about to get a mouthful.
Old Feb 1, 2010 | 12:05 AM
sno's Avatar
sno
1. Use it
2. Burn tranny
3. Take receipt back to dealership
4. ????
5. Profit!
Old Feb 1, 2010 | 04:20 AM
dynamic21's Avatar
dynamic21
Originally Posted by sno
1. Use it
2. Burn tranny
4. ????
5. Profit!
+10
Old Feb 1, 2010 | 04:58 AM
huyrua's Avatar
huyrua
1. Use it
2. Burn tranny
4. ????
5. Profit!
Knowing stealership, they'll blame the problem on something else. Just return the fluid and get the correct one.
Old Feb 1, 2010 | 05:15 AM
JasonZ-YA's Avatar
JasonZ-YA
1. Use it
2. Burn tranny
4. ????
5. Profit!
that would be nice, but in all actuality, they would say you installed it and didnt use your owners manual.........and say you asked for that fluid.........your word against theirs.........
now if you took it in and you got a receipt of them putting that issh in your car at the service department and later your car blew up and then item 2 happened..........then i think you could end up with completing item 3-5... but that would be a bisch of a time when all you wanted was a tranny fluid flush..........
-J
Old Feb 1, 2010 | 08:03 AM
ZPHILE's Avatar
ZPHILE
-JasonZ_YA
Bottom Line - use the right fluid, don't waste your time and be done with it!
sales@czp
Sep 23, 2019 03:30 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Cashwin
Oct 1, 2015 06:36 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
