Found a 350Z design flaw :(
Old Oct 24, 2003 | 05:21 PM
AndyB's Avatar
AndyB
Default Found a 350Z design flaw :(
While reading my owners manual I discovered what seems like a design flaw.
The trunk can only be opened using electric power. That could be a problem if you kill the battery or blow fuses.
Nissan thought of that and put a backup opener in the storage box behind the passenger's seat. BUT, if you have no battery power and you have power seats how the HECK are you going to get in there to access the backup system?
It's even worse on the roadster. To put the top up in case of electrical failure you can disconnect the motors from the top mechanisms. To do that you need to get in the trunk. To do THAT you need to move the passenger seat!
I don't suppose there is some way to move the seat without power?
Grrr, why do I think of these things!?!?!?!
Old Oct 24, 2003 | 07:18 PM
xw34x's Avatar
xw34x
i dont know about your model.. but i have a lever on the back of my passenger seat that i can pull easily from the driver side to bend the seat over so i can reach the storage box behind it.. if that's what u're talking about..
Old Oct 24, 2003 | 08:01 PM
Zsilverstone13's Avatar
Zsilverstone13
For the coupe, there is a secondary trunk release under the strut tower bar in the trunk. I am not sure if the roaster has one or not.
Old Oct 24, 2003 | 10:38 PM
xw34x's Avatar
xw34x
yea.. i dont know how to use that thing even though i knoew where it is.. any tips?
Old Oct 25, 2003 | 09:02 AM
Jason's Avatar
Jason
Provided your car is unlocked, you can just pop the trunk with the button over the license plate.
And yes, the Zs with electric seats still have a manual release on the right side of the seat.
Old Oct 25, 2003 | 12:13 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Correct, you don't need power to pop open the hatch with the button over the rear license plate.
Old Oct 26, 2003 | 05:22 PM
350Z-RED's Avatar
350Z-RED
the manual says the backup trunk opener is on the strut bar
Old Oct 26, 2003 | 08:09 PM
Jason's Avatar
Jason
That's because ALL cars now have a backup trunk opener INSIDE the trunk. This is incase a person gets locked inside the trunk.
That said, you'd have to be really dumb to get yourself locked in the trunk of a coupe
Old Oct 27, 2003 | 04:08 AM
AndyB's Avatar
AndyB
Default Seats
No kidding?
Hmmm I will have to look again. I guess I just overlooked it .
Old Oct 27, 2003 | 04:09 AM
AndyB's Avatar
AndyB
Default release
Really?
I thought it was just an electrical switch.
Even if this is true, you need electricity in the car to unlock the trunk.
Old Oct 27, 2003 | 04:11 AM
AndyB's Avatar
AndyB
Default electric
On the electric seats that button is also electric.
It is sort of a nuisance since the electric is slow.
It would have been nicer of the seat back switch just unhooked the seat back from the electric motor. You could then tips the seat up quickly to get in the rear storage area.
Oh well.
Old Oct 27, 2003 | 11:05 AM
junglist350Z's Avatar
junglist350Z
my old legend had electric seats but i could move the seat back up or down with a manual thing so that passengers could get in or out quickly.
Old Oct 27, 2003 | 11:43 AM
Jspec350z's Avatar
Jspec350z
The switch over the license plate is a power switch. If you disconnect your battery it will not work. Anyone that says different has not tried it with the battery disconnected.
Old Oct 28, 2003 | 10:52 AM
Subbacultcha's Avatar
Subbacultcha
there is no design flaw.
1. I have the touring w/ power seats. The passenger seat tilt function is still just a manual lever. On that seat, only the forward/back is electric.
2. There is a manual pull string on the bottom of the strut bar. If you have no power you can contort yourself from the front seat, reach back to the underside of the strut bar and pull the string. (the finger pull-tag on the end of the string is velcro'd to the strut so that you can't see it) and the hatch opens. tada.
Old Nov 7, 2003 | 06:49 AM
AndyB's Avatar
AndyB
They must have changed it.
On my 2040 roadster the seat is electric (sliding front and back) as well as electric recline. There is no manual release for the seat back that I can see.
Old Nov 7, 2003 | 08:06 AM
ares's Avatar
ares
Veteran
I believe that is a roadster feature not a 2004 feature, and also obviously, no strut bar, meaning no manual trunk release
Old Nov 7, 2003 | 08:46 AM
AndyB's Avatar
AndyB
Default Manual trunk release
Ahh, but there IS a manual trunk release.
It is in the glove box behind the passenger seat....
which can't be moved without power.
D'Oh!
I am not really too worried. Even a battery to dead to start the car can probably move the seat. If is more of a "what were they thinking" sort of thing.
Old Nov 7, 2003 | 08:54 AM
ares's Avatar
ares
Veteran
it makes no sense at all actually, cause the purpose of the strut bar release is not for people to use... its a safety feature designed to allow people trapped in the trunk to get out... kinda odd cause its a hatch, but its required for all cars with a trunk I thought, just incase. but the manual release in the glove box wont help someone locked in the trunk.(specially since itd have to be a 2 year old baby to fit )
Old Nov 7, 2003 | 09:05 AM
350zluvr's Avatar
350zluvr
How the hell did you already get the 2040 model? Do you drive it or fly it? Does it have like a 12.5L and afterburners? You must show pics!!!
P.S. sorry for being a smarta$$, justa little bored at work and when I saw that I could not help my self to resist.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
