HELP 5TH GEAR Crunch!
Old Feb 14, 2010 | 12:30 PM
Godly350's Avatar
Godly350
Default HELP 5TH GEAR Crunch!
I have read into this and appears this happens to a lot of Z's. I have a 05 Touring model with 39,xxx miles. I've had the crunch going into 5th for a while, but now its time to just fix this problem I have. Would just a Flywheel solve this problem? please help me as to what I should get to save help my car, and I'm always down for upgrades so if there is anything else that would help me gain a little bit of power with this problem that would be great.
Old Feb 14, 2010 | 01:06 PM
grizz311's Avatar
grizz311
so you want to fix a tranny/clutch problem by increasing horsepower??? wut
and what do you mean will a flywheel solve this problem? First you need to figure out if it is in fact the flywheel that is causing the problem in the first place.
Old Feb 14, 2010 | 01:53 PM
Godly350's Avatar
Godly350
yeah I will being going to a local tranny shop by me during the spring, and I'm not sure what there going to tell me, but I've done some research and found out im not the only one with this 5th gear crunch..Im asking the people who had this problem.. how did you guys fix this? i mentioned a fly wheel because I've read this usually help with the crunch problem.
Old Feb 14, 2010 | 03:21 PM
nismonian's Avatar
nismonian
do you mean grind?? do you have a warranty?
Old Feb 14, 2010 | 04:05 PM
mistanismo's Avatar
mistanismo
It's your transmission.
Old Feb 14, 2010 | 06:58 PM
How did you come up with a flywheel will fix a transmission?
Old Feb 15, 2010 | 11:37 AM
Godly350's Avatar
Godly350
ive only herd that the flywheel can help in this situation..but ive also herd that i may have to get new syncros for my gears? any suggestions of what i should be looking at price range to fix this? and no im not under warranty.
Old Feb 15, 2010 | 11:59 AM
JCat's Avatar
JCat
Driving at highway speeds, 60mph+, press and hold in the clutch peddle and shift between gears. Shift from 4 to 5 to 6 . . . . .and then down from 6 to 5 to 4.
Does it go into each gear smoothly without any grinding noise?
If you have difficulty shifting between gears, or hear a GRINDING noise it means that the synchros inside your tranny are bad. The best solution is to replace your tranny with model CD009. Yes, it took Nissan 9 tries to get this problem solved.
How much does this cost? Well, you might want to replace your pressure plate, clutch disk, throw-out bearing, as well as your tranny. A rough estimate would be $2,000.
Old Feb 15, 2010 | 12:13 PM
Godly350's Avatar
Godly350
ya. the gears crunch..bla alright well looks like ill be getting a new tranny haha dam..thanks for the help..any suggestions were to get this done? i live in long Island...
Thanks Jcat for the help
Old Feb 15, 2010 | 02:39 PM
RandyK1's Avatar
RandyK1
$2000 is way low, Nissan replaced my pressure plate, clutch disc and throw out bearing for $1350 for parts and labor. Add the trans and you will be spending alot more $$
MAsSIVrOOM
Oct 20, 2023 10:50 AM
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
