Another Way to Program Keyfob?
Old Feb 17, 2010 | 11:49 PM
chaofun's Avatar
chaofun
Default Another Way to Program Keyfob?
I just bought a new keyfob off ebay because I lost my old one. I followed the instructions from various posts that tell me to put the key in and out of ignition 6 times within 10 seconds, and it's just not working. I'm not getting the hazard-blink-of-success. And I've tried a lot of times: fast, slow, medium.
I have an 04 350z if that makes any difference. I read some brief descriptions of dealers turning the key on and off (versus just sticking key in and out and not turning). Does anyone know how to program a key this way?
Thanks
Old Feb 18, 2010 | 12:58 AM
fokaisnake's Avatar
fokaisnake
Does your new FOB have a battery in it? Bought one off ebay a while ago and it didn't come with one.
Old Feb 18, 2010 | 02:46 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Here's the instructions that I found.
Old Feb 18, 2010 | 07:28 AM
chaofun's Avatar
chaofun
Thanks. I tried the method in that picture many many times. And it's just not working. And the keyfob came with a battery. But if the battery's dead, it wouldn't matter because I still can't get into hazard-light-of-success mode, which doesn't even use the keyfob yet.
Anyone with ideas as to what's wrong and why I can't program my keyfob by inserting my key into the ignition in and out?
Old Feb 18, 2010 | 08:00 AM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Ok, You MUST get in the car, Lock the doors with the lock switch first. Then do the key cycle. If it doesnt work, Turn key fully on, turn off, Remove key, Open door and start over. You have to be somewhat deliberate when you put the key in and out. Too fast and it won't work. DO it slow and fully engage
Old Feb 18, 2010 | 08:33 AM
ImWeeZzel's Avatar
ImWeeZzel
by any chance did you get it from remotes4less?
Old Feb 18, 2010 | 09:16 AM
chaofun's Avatar
chaofun
That's what she said. haha. but no really. I'm in the car. doors are locked. I even locked unlocked and locked. I've done it slow, medium, and fast multiple multiple times. Is my wiring messed up? I have an aftermarket headunit if that makes any difference. I'm not sure if this is true, but I think after installing the HU some years back, when I leave the keys in the ignition and open the door, it doesn't beep. I thought maybe the car used to beep when you leave keys in ignition, but I'm not sure. It's been a while. Is something broken?
Old Feb 18, 2010 | 12:26 PM
TreeFiddyZee
Do WHAAAAT!?
When you leave the key in and open the door, does your dome light come on? Does your window drop? None of these worked on my car after flood damage and I had to get the BCM (body control module) replaced, which is also related to the keyfob setup. After they put in the replacement BCM, they had to reprogram my fobs and my keys.
Old Feb 19, 2010 | 12:40 AM
chaofun's Avatar
chaofun
Thanks for the idea, but my dome light comes on with the key in. And the window does that mini-drop with the key in.
So it's probably not the BCM?
sighhh. I don't know why I can't just program my keyfob.
Old Feb 22, 2010 | 02:58 AM
maXmood's Avatar
maXmood
Under Boost!
take it to the dealer and ask them to do it, save ur self the trouble.
Old Mar 1, 2010 | 01:05 PM
Ollie's Avatar
Ollie
actually it should beep when you leave your key in ignition - open the door AND lock the door by lock switch ... then my Z does beeping
unfortunately I have no idea for the main problem
BTW first post - hi forum
Old May 6, 2010 | 06:47 PM
snuffy11's Avatar
snuffy11
okay,, on a related subject.. I need to know how to reprogram my key so that i can start my car.. I lost one key the other day and found it but, only after paying my local Nissan dealer for a new key and program to the tune of $161.00.. so, if there is a sequence that I can do myself to save some much needed dollars,, I am all ears..
Thanks,
Snuffy11
Old May 6, 2010 | 08:10 PM
ImWeeZzel's Avatar
ImWeeZzel
I was told like the tmps programming, its a dealership thing... However i too am curious... bump for some knowledge...
Old Dec 16, 2013 | 12:17 PM
Z33Garage's Avatar
Z33Garage
I get it into programming mode, but when I press they key on the remote nothing happens...any idea? (new battery btw)
Detailed Image
Cleaning & Detailing
Sep 18, 2015 11:43 AM
Detailed Image
Sep 16, 2015 04:56 AM
abz123
Feb 6, 2003 01:19 PM
Todd
Sep 7, 2002 07:14 PM
Todd
Aug 24, 2002 08:31 AM
