starts but no rpm's
Old Apr 3, 2010 | 05:39 PM
350z nismo's Avatar
350z nismo
Default starts but no rpm's
have a 06 350z and it starts but i give it gas and the rpm only goes up to like 1500...can anyone help?
Old Apr 3, 2010 | 06:04 PM
SatchScream's Avatar
SatchScream
Give it more gas.
Old Apr 3, 2010 | 06:33 PM
350z nismo's Avatar
350z nismo
i did all the to the end and rpm's only go up to 1500 or so
Old Apr 3, 2010 | 06:44 PM
Jay'Z's Avatar
Jay'Z
reset ecu
Old Apr 5, 2010 | 10:08 AM
350z nismo's Avatar
350z nismo
k thanks ill try that... hopefully it will work
Old Apr 5, 2010 | 11:12 AM
spoolin_gt's Avatar
spoolin_gt
is it just the tach that's not moving or is the engine not revving up at all?
Old Apr 5, 2010 | 11:25 AM
Z_HighSpeed's Avatar
Z_HighSpeed
do you hear the engine revving past 1500? or is it stopping?
did it throw a code?
Old Apr 5, 2010 | 12:06 PM
Zazz93's Avatar
Zazz93
Code please? I think the rev up had a oil temp sensor that will put the car into limp mode at a certain temp. If that is bad it would do that. Throttle body or accelerator problems would cause that too. Try and get a code.
Old Apr 5, 2010 | 12:25 PM
Zazz93's Avatar
Zazz93
Here a look at the Fail Safes for various problems. Although most for the Non-Revup DE.
Old Apr 17, 2010 | 12:14 PM
350z nismo's Avatar
350z nismo
not reving up at all
Old Apr 17, 2010 | 12:16 PM
350z nismo's Avatar
350z nismo
ill try to get a code and post it up as soon as i can which will proabably be monday
Old Apr 28, 2010 | 09:38 AM
350z nismo's Avatar
350z nismo
one of the codes is p2135/ p2135(hd) and there was another code but it cleared and this code came up can anyone help me out?
Old Apr 28, 2010 | 10:02 AM
temoku's Avatar
temoku
http://www.*********.com/zwiki/OBD-I..._(Engine_Codes)
the ***** should read "three fifty zeeee dash tech"
throttle position sensor. seems easy enough to fix
Old Apr 28, 2010 | 07:22 PM
Zazz93's Avatar
Zazz93
Here what the FSM say is the most likely problem.
sherm
Apr 11, 2020 05:21 PM
Justin100
Nov 29, 2015 03:58 PM
Dymsi
Sep 29, 2015 11:32 AM
