Attention noise gurus
I'v got a weird ticking noise, which sounds like its coming from the front.
driver side ( right here in OZ ) . Happens when turning left, speeds up and slows when accelerating and slowing, straight line no ticking, with or without brakes applied.
06 track roadster with Rays GTF's 9.5X19+17 with 245/19/35 on the front. New DBA 5000's with Ferodo 2500's, Bilstein pss10's.
I'm thinking it may be bearings or steering related.
Any ideas , thanks in advance.
I have the exact same problem.. it has begun to shake the hole car actually..
I believe it is the HUB assembly/ wheel bearing, I hope it it is the wheel bearing..
the shaking/noise is getting worse after 80Mph am I right?
I did check it for movement... it did'ny move actually....
my mechanic told me it could be the tire as well.. but I know it is'nt that, because it also did it with my old tires..
so I'm a little lost.
Well! An update, bearings seem good, no wobble. CV boots are in good condition. Driver side ( right for OZ ) end links - no movement.
But I did wash the car and hosed the wheels, the ticking stopped for a bit but now its back.
Bugger
Bugger
Ok!!!!
Removed the suspect front wheel, noticed the lugs (kics 40's) had been installed tighter than normal, installed wheel hand tightened. All good.
Go figure, looks like my garage guy may have over tightened when re-installing.
