CHECK ENGINE, SLIP and TCS LIGHT is on! PLS HELP
Old Jan 8, 2016 | 05:46 PM
  #41
DeusExMaxima's Avatar
DeusExMaxima
Originally Posted by travlee
now give it a couple days to make sure it doesn't return.... but i think you got it
Yes..I think so. The lights would certainly have come on by now as I have driven about 30 miles of about seven or eight short trips and the car has run perfectly
Old Jan 11, 2016 | 11:48 AM
  #42
DeusExMaxima
I fixed my gas gauge by cleaning the sending units and drove the car on several more short trips. Still no warning lights and the car is running great.
Old Apr 7, 2016 | 11:09 AM
  #43
DougEvans's Avatar
DougEvans
Hi DeusExMaxima. Just checking as my Z seems to be having the same issues. Is your Camshaft Position Sensor solution still working good for you? Did you replace both? Thanks in advance!
Old May 7, 2016 | 07:53 AM
  #44
Semih166's Avatar
Semih166
Default !!! Fixed !!!!
!!! FIXED !!!! I turned my front rotors on my 2008 Maxima. Right after that the car had long start time cel on tcs vcs light came on. After diagnostic the code it was camshaft sensor bank 2 ( P0345) I replaced the sensor, the car starts right up. I havent driven it yet, but the cars start right away. It is strange that problem happened right after replacing the front rotors. I am not sure if it is just a coincidence or something triggered it during replacing the rotors. I just wanted to share my experience.
Old Nov 19, 2023 | 03:33 PM
  #45
AndyKlein's Avatar
AndyKlein
Changed all rotors and pads, 2 months later TCS, Slip and CEL on and car barely starts. Will grab codes tomorrow, check fluids etc.... more than coincidental I'd say!
Andy
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
