hard time restarting the car
Old May 3, 2010 | 07:32 PM
demundus's Avatar
demundus
Default hard time restarting the car
If i drive my car for any time frame, then stop and quickly start it again (grocery, ATM, etc) it wont start. If/When it does start it barely sputters to life and makes a LOUD and LONG belt squeek noise... kinda like the serpentine one on a cold start. Furthermore, the starter sounds heathy, it just sits and turns and turns and turns.
I just changed the spark plugs a month ago, stayed OEM NGK's.... it fixed my cyl 2 misfire that had been plaguing me on the highway for awhile, and now this. Other than this issue the car runs excellent, and i even saw some improved gas mileage and throttle response from the new plugs.
Any ideas? (not throwing codes or anything as an fyi)
Old May 3, 2010 | 08:22 PM
POWUH's Avatar
POWUH
did you check your battery belt?
Old May 3, 2010 | 08:30 PM
MODDEDZ's Avatar
MODDEDZ
Might need a new battery.
Old May 3, 2010 | 10:19 PM
13ringinheat's Avatar
13ringinheat
I have the SAME EXACT problem and it happened to me today. I live in florida as well. very interested to see what people from this website have to say. I am going to take it to the mechanic day after tomorrow and will update if i figure it out before someone here does.
Old May 4, 2010 | 05:04 AM
JRUBIO350's Avatar
JRUBIO350
same thing happens to me, i am also going to get it checked out this weekend
Old May 4, 2010 | 01:20 PM
demundus's Avatar
demundus
let me know what you guys find, this is embarrasing in a crowded place and also downright silly
Old May 4, 2010 | 02:35 PM
13ringinheat
Well mine seems like the battery. I tried to start it today and when i used my car alarm to unlock the car the car wouldnt unlock so more than likely a dead battery. Will keep you posted if anything new comes up. From what i read online it seems like this could be a cause from anything including, fuel pump, spark plugs or faulty key programming.
Old May 4, 2010 | 02:50 PM
MODDEDZ's Avatar
MODDEDZ
+1...
Old May 5, 2010 | 03:34 PM
13ringinheat
Yep got the battery replaced and the car works fine now. Also to note the car battery just flat out died. I tried to jump start it and it wouldnt jump start. Never seen a car battery flat out die like that ahhh well all seems well for now.........
Old May 5, 2010 | 03:41 PM
haeshik's Avatar
haeshik
^glad u got it replaced, its the battery fasho!
Old May 5, 2010 | 05:13 PM
demundus's Avatar
demundus
Found out my battery is from like 05. im going to replace it and see what comes next....
thanks guys.
Old May 10, 2010 | 02:41 PM
demundus's Avatar
demundus
Bumping this, its not the battery. Cleaned the **** out of the MAF and the sensor, still having the issue. It's going to the mechanic on wednesday. I'm so frustrated at this car, it drives great but there are so many little things that go wrong
Old May 12, 2010 | 02:20 PM
demundus's Avatar
demundus
fixed. my camshaft sensor bolt was missing... gotta love a used car.
etkms
Jun 19, 2022 06:30 PM
m_0g
Jun 3, 2021 10:05 AM
Vigman
Nov 17, 2015 04:34 AM
davidm350
Oct 31, 2015 02:28 PM
