Clutch install help........
Old May 17, 2010 | 02:35 PM
mw9's Avatar
mw9
Default Clutch install help........
Ok, just installed my new Act clutch and flywheel. I replaced the Master and Slave cylinder and bled with all new Motul fluid. My question is, do I still have air in the system? The pedal only returns to little over half way. When I press the clutch in feels good. but my pedal does not come all the way back to its original position, or do I have to adjust the height of the pedal? The manual says it needs to be in between 6.73-7.05 in, I am about at 5 in. Thanks again.
Old May 18, 2010 | 10:01 AM
JasonZ-YA's Avatar
JasonZ-YA
why did you replace teh master and slave???
i think you just need to keep bleeding?
what year Z do you have?
-J
Old May 18, 2010 | 10:56 AM
cheshirecat79's Avatar
cheshirecat79
I agree. Air in the line.
Old May 18, 2010 | 11:29 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
how are you bleeding the line? manually? you may be at it for awhile if so..
Old May 18, 2010 | 02:25 PM
mw9's Avatar
mw9
-J
2003, 105,000 miles on car. I figured just changed everything out. Kept bleeding it and the pedal has returned all the way up. I manual bled it and used Motive power bleeding like your post. In the future I would like to change out the clutch reservoir. I'll going to drive it around now carefully for awhile. Thanks again guys.
Old May 18, 2010 | 05:54 PM
JasonZ-YA's Avatar
JasonZ-YA
AWESOME...
so u used the motive universal adapter on the oem clutch reservoir..??
-J
Old May 19, 2010 | 02:37 AM
mw9's Avatar
mw9
AWESOME...
-J
Gorilla tape, ha. worked fine. Wouldn't recommend, you way would be the correct way. Thanks again for all your good write ups.
Old May 19, 2010 | 04:07 AM
JasonZ-YA's Avatar
JasonZ-YA
lol awesome...
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
