NEED HELP: Major headlight problem.
Old Jun 20, 2010 | 01:58 PM
kihun's Avatar
kihun
Default NEED HELP: Major headlight problem.
my passenger side was headlight-less for about a month and I guess rain dropped on one of my headlight harness because it would not turn on when i put my headlight on. blinkers and idle lights are on but the headlight..I know I'm a dumb *** for not covering that harness with electric tape.
I replaced hid bulb and even ballast but still the same. could it be the harness that's connected to the whole engine assembly because of rain? if so, how can i solve this issue?
Old Jun 20, 2010 | 03:16 PM
LaoSiFu's Avatar
LaoSiFu
Cheaper solution and I hope this is it but remove the ballast, shake off the excessive water, let it dry up under the sun and reinstall it. If that doesn't work I suggest perhaps switching the ballast from the other side to see if that is it. Let me know how that turns out.
~Robert
Old Jun 20, 2010 | 03:22 PM
kihun's Avatar
kihun
i don't think it's ballast issue. i think it's the harness that's connected to the headlight assembly. because I had another ballast. let's just say I tried with three different ballast and it did not work.
Old Jun 21, 2010 | 02:23 PM
kihun's Avatar
kihun
guys. signals and idle lights work but hid dont work. i swapped ballast and hid bulbs but still dont work. what could it be?
Old Jun 21, 2010 | 05:57 PM
TheFarmer's Avatar
TheFarmer
Check fuses?
Old Jun 22, 2010 | 05:14 PM
LaoSiFu's Avatar
LaoSiFu
Originally Posted by TheFarmer
Check fuses?
Was going to say that next
~Robert
Old Jun 22, 2010 | 06:15 PM
kihun's Avatar
kihun
forgot about that. ill check it tomorrow! where is the fuse at? the one under the hood near by the battery or under the seat?
Old Jun 22, 2010 | 06:32 PM
kihun's Avatar
kihun
i forgot to mention that the driver side headlight works fine. do they have fuses for two different headlights?
Old Jun 23, 2010 | 02:21 PM
kihun's Avatar
kihun
where the hell is the fuse? i looked under the battery compartment and there is no headlight fuses.. under the driver side left no fuses either.
Old Jun 23, 2010 | 02:48 PM
kihun's Avatar
kihun
fixed the problem. fuses were behind the battery compartment.
Old Oct 30, 2012 | 10:38 AM
Z PHAT Z's Avatar
Z PHAT Z
What was the problem? I'm having the same issue. Thanks.
Old Nov 1, 2012 | 10:29 AM
sluggoZ's Avatar
sluggoZ
It must of been the fuse.
Old Nov 5, 2012 | 01:53 PM
Z PHAT Z's Avatar
Z PHAT Z
My fuse is fine. Guess the ballast next?hehe
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
3vilbunny
Jul 18, 2017 05:10 PM
JGee450
Sep 30, 2015 04:32 AM
