a/c clutch problems
Old Aug 24, 2010 | 04:24 PM
350sexZ's Avatar
350sexZ
Default a/c clutch problems
ok ive been searching thru a few threads and didnt find any that helped, so that being said i have some questions. about a month ago ive been having trouble with my a/c, when i would idle it would throw out warm to hot air. As i would drive it would start blowing cold. So i check the freon pressure, that was good and at that time the clutch was spinning. So my question is if the compressor starts to go out will it work off and on are just completlly stop working? I also notice that when im driving and then come to a stop about 30 seconds later i can hear the clutch turn off and when i start driving again it cools like a champ. One other thing i have done is have the car idling for about 20 minutes, and in those 20 mintues the clutch would turn on but only for a few seconds then turn off. So i was wondering if it could be some kind of relay, but then thought, when a relay goes out it goes out it doesnt just work and not work. i was also thinking that maybe it is a clutch cycling switch. any ideas
any advice and input would be appreciated
thank you
Old Aug 24, 2010 | 07:10 PM
350sexZ's Avatar
350sexZ
well after driving home from my parents house i found one problem out, my car started to over heat. the needle was at the h when i popped the hood the drivers side fan wasnt spinning and the one on the passanger side was spinning preety slow. would that be part of the a/c issue also?
Old Aug 24, 2010 | 11:33 PM
winchman's Avatar
winchman
Yes. The AC condenser depends on air flow just like the radiator does. Fixing the fan problem will cure both the overheating and the AC performance.
Old Aug 25, 2010 | 05:31 AM
350sexZ's Avatar
350sexZ
Ok thank you, I ordered the fan assembally this morning,won't be in for three days. So looks like I'm gonna be driving with the heater on for awhile.
Thanks the the response
Old Aug 25, 2010 | 05:53 AM
JasonZ-YA's Avatar
JasonZ-YA
drive in tx with heater on...........ouch...
rent a subcompact from budget man...
dont risk running your engine hot around town..
-J
Old Aug 25, 2010 | 06:37 AM
y0shi's Avatar
y0shi
While your changing the fan, check your radiator fluid level. Make sure its full.
Old Aug 25, 2010 | 11:35 AM
350sexZ's Avatar
350sexZ
-J
yeah very true ill probably just use the wifeys car for the mean time
yeah i checked the coolant its still good despite being boiled last night
Old Aug 25, 2010 | 12:11 PM
350sexZ's Avatar
350sexZ
alright so when i came home from work i turnied the car on for about 5 minutes then drove it for about 15 mintues when i came back to the house the needle was in the middle, so while it was idling i was rev up to about 3k for about 10 seconds and every time i let off the temp would rise. so then i popped the hood and no fans were spinning, so i banged on the assembly and the drivers side started to turn slow then stop.
i had a strong feeling it was the fan last night but wasnt 100 percent sure because i couldnt see much in the dark. but today the sun was on my side and found out the fan motors are done.
thanks again guys for the help
Old Aug 25, 2010 | 12:29 PM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
If you have a volt meter check the voltage at the fan motor connector. If it is getting power and still not working, you need motors.
Old Aug 25, 2010 | 08:34 PM
winchman's Avatar
winchman
It might be the relays instead of the fans themselves. Look around pages EC-543 to EC-556 ('07 service manual) for more info.
Old Sep 1, 2010 | 03:45 PM
350sexZ's Avatar
350sexZ
Alright this is just a little update. I turned out the be the fan assembly. Put the new one yesterday and everything is up to par now a/c is working and engine cooling
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
