Another clunk clunk clunk thread....
Old Sep 12, 2010 | 12:39 PM
Tackett's Avatar
Tackett
If I can't figure it out. I guess I'll take It in and have it looked at.
Though I consider taking your car to the mechanic equivalent to paying someone to grope your wife.
Old Sep 12, 2010 | 04:32 PM
12AutoX's Avatar
12AutoX
^^^^ Funny but true. You don't have any mechanic friends whom you can trust not to rip you off?
Old Sep 12, 2010 | 08:34 PM
Tackett's Avatar
Tackett
Nope.
If I want it done right, I usually just do it myself.
Unless it's something like this that is truly puzzling.
It's hard to tell what they will try to pull over on me when I take it in.
Old Sep 13, 2010 | 09:21 PM
Tackett's Avatar
Tackett
Ok. Update.
I jacked the car up and spun both front rims as fast as possible with my hand.
Driver side was fine.
However
Pass side, I heard a slight clunking sound with each rotation. Not as pronounced as when driving, but I imagine the weight of a few thousand pounds will amplify the problem.
I looked and looked to see if the wheel or hub was hitting something.
I found nothing. The sound seems to come from thin air.
Watcha think? Wheel bearing?
Old Sep 13, 2010 | 09:24 PM
Tackett's Avatar
Tackett
If so, do you think this is something I can replace myself? I'm pretty handy with a wrench.
I found replacements with google for around 60.00.
Old Sep 13, 2010 | 11:05 PM
winchman's Avatar
winchman
You should be able to handle it. It's bolted to the spindle/knuckle with 4 bolts that should be accessible once the wheel, brake caliper, rotor are removed. There's a wheel speed sensor nearby, so be careful not to damage it.
Section FAX of the service manual shows the torque for the bolts.
I'd suggest only using OEM or name brand parts on something like this. It's no place to take chances with cheap knockoffs.
Old Sep 15, 2010 | 08:56 PM
Tackett's Avatar
Tackett
Sweet. Got one on order, will give it a shot when it gets here. Thanks for everything bro!
Old Oct 20, 2010 | 01:44 AM
Juci's Avatar
Juci
Have you solved this problem? Maybe having that same thing...
Old May 18, 2012 | 11:11 AM
Twenty4's Avatar
Twenty4
Bump for anyone knowing what this is?
I PM'd the OP but he hasn't been on in a year... extensive searching and this is the only thread with the same problem after watching the video on page 1.
Thanks!!
Old Jul 3, 2012 | 08:06 PM
xman2yman's Avatar
xman2yman
Same.
fernandito7
May 3, 2011 08:51 AM
SuperRobin
Aug 23, 2004 08:25 AM
Dissolved
Dec 29, 2003 07:01 AM
failsafe
Oct 16, 2003 09:51 AM
