SES light after coilpack reconection mix-up
Old Sep 18, 2010 | 08:21 PM
FastWhiteZ's Avatar
FastWhiteZ
Default SES light after coilpack reconection mix-up
Hey guys, I changed my plugs yesterday and while reconnecting my coils with the harness I mixed up cyl #4 with #6. It idled rough for a second then I turned it off and double checked my work. I found the mix-up and fixed it, but the SES light won't shut off even after ECU reset and battery unplug methods. The car runs fine and I know the light was from the coil mix-up. Is there anything else I could do to shut the light off or should I just let it be and it will take care of itself?
Old Sep 20, 2010 | 07:19 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
If the light is still coming on after the reset then your ECU is still seeing something it doesn't like. Check the codes.
Old Sep 20, 2010 | 07:53 AM
Zazz93's Avatar
Zazz93
^Exactly, I think there may be a second problem that hasn't been addressed.
If the light comes on immediately after reseting the ECU look for unconnected connections.
Old Sep 21, 2010 | 04:32 PM
FastWhiteZ's Avatar
FastWhiteZ
I retraced my steps and found a loose relay. It was partially connected so it was giving me mixed results. Thank God it was something simple. Thank you for the help.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
