Any difference between Brembo and Non when changing pads/Rotors?
Did a search and didn't find anything (maybe it's the user?
). Anything special I should know about changing the pads/rotors on my Brembo's compared to normal brakes?
This was helpful to me as a reference. Once you get in there, they are super easy.
http://www.youtube.com/watch?v=LZLX3jkgsJw
Cool vid. Seems easy enough. Would have never of guessed that you could replace the pads without removing the calipers. What about replacing the rotors? Follow those steps and then unbolt the caliper?
just take the caliper off then take out the pads and then slowly push back in the pistons so you dont create air in the lines then replace the pads. yup and when replacing pads its always good to turn the rotors so you can have a nice new smooth surface so the new pads can make there own grooves if not you'll have to be replacing those new pads in no time.
Brembos are considered "fixed mount, top loading" brake calipers...where the non brembo 350z brakes are called "floating" brake calipers.
They are Ideal for track day pad changes...ease of swaps...
also, thought i would mention:
Another awesome tool to keep in mind is once you pull the pins and pull the pads out, you can use this tool to press the caliper pistons back in so you can drop the new (thicker) pads in:
http://www.mamotorworks.com/corvette...-114-7794.html
Also,
http://www.etoolcart.com/lisle-tools...-lis25750.aspx
http://cgi.ebay.com/ebaymotors/Disc-...motiveQ5fTools
http://www.amazon.com/Disc-Brake-Pis.../dp/B0031FQ01O
http://cgi.ebay.com/ebaymotors/Lisle...motiveQ5fTools
-J
Also,
-J
-J
