premature wearing of rearhub bearings
Old Feb 17, 2011 | 06:53 PM
jlz33's Avatar
jlz33
Unhappy premature wearing of rearhub bearings
i had to replace rear hub bearings(the L/H side was really bad,the R/H side wasn't too bad but replaced both sides at same time $700)on my z that has only 35,xxx miles on it (05 model). never had a car that needed a new one at that mileage,i don't even remember replacing the bearings on any of cars that i have owned. is this a common problem on 350z's. is anyone out there that had a similar problem as i have or is this something that a z owner has to do every 30,000 miles or so.
Old Feb 17, 2011 | 07:23 PM
Spike100's Avatar
Spike100
^^ Any suspension modifications? …spacers? ….aftermarket wheels?
--Spike
Old Feb 17, 2011 | 08:07 PM
terrasmak's Avatar
128k one one of my stock rear bearings. The other got wiped out sliding off the track.
Old Feb 17, 2011 | 08:17 PM
engiNERD350Z's Avatar
engiNERD350Z
I have a 2005. Had mine replaced left rear at 45K miles. I have 15mm spacers but still I never really came up with a good reason why it happened other than the spacers but the other side is just fine.
Old Feb 17, 2011 | 10:03 PM
jlz33's Avatar
jlz33
lowered 1'' , 20" wheels , 15mm wheelspacer to accommodate bbk, camber kit for rear.
Old Feb 17, 2011 | 10:05 PM
jlz33's Avatar
jlz33
--Spike
20'' rim,lowered 1",15mm spacer to accommodate bbk, and rear camber kit.
Old Feb 17, 2011 | 10:20 PM
jlz33's Avatar
jlz33
how did you managed to keep it that long? any mod to your suspension and do you track often? which means that you push that car to the limit time to time right? see,i have never taken my car to any track.always driven carefully,no dumping of clutches here. i hope that failed bearing wasn't due to the mod i did mentioned above.
Old Feb 18, 2011 | 06:29 AM
I think you answered your own question. Baller status is not cheap.
Old Feb 23, 2011 | 08:18 PM
microsteve40's Avatar
microsteve40
Know it all
What are the symptoms of the hub bearings giving out? My driver side wheel is wobbling, and I've had EVERYTHING checked, and can't figure it out. Had my wheel balanced 3 times, 2 different tires, had the wheel checked out (it spins out beautifully), all the bushings, etc. My mechanic can't find any play in the bearing, but could that still be the problem? I'm at a loss...
Old Feb 23, 2011 | 08:45 PM
omsin523's Avatar
omsin523
could be your compression rod bushing is shot thats why theres play in the wheel
Old Mar 1, 2011 | 07:10 PM
jlz33's Avatar
jlz33
Default wheel hub bearing
after jacking up the entire rear end i found driver side wheel wobbled when i grabbed it and moved it around in all different directions. that meant one thing worn bearing. took the car to the shop and replaced it ($700 for both sides) i hope this doesn't repeat after another 35,000mi or so.
Old Mar 1, 2011 | 08:45 PM
LB350z07's Avatar
LB350z07
Try changing ur hub that's what I did n now its good
Obadabot
Jun 18, 2023 11:31 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
samansharif
Sep 25, 2015 12:31 PM
