Ses; vdc; slip
Old Mar 7, 2011 | 05:20 PM
MSBx03's Avatar
MSBx03
Angry Ses; vdc; slip
Hey guys, I'm new to the VQ world. Just bought a '04 touring coupe w/60k on it, 6spd MT.. Had it for about a week now.. Went out to go crank it up and run to the store.. Turned the key and it started right up nice and easy like usual, but it only stayed started for about 2 seconds then it died. I tried to crank it again and it didnt crank up for about 7 seconds.. It sounded like it was really struggling. After it got started it stayed on but the SES light came on along with the VDC and SLIP(whatever that means).. I did some reading and apparently a lot of people have this problem and its because of the camshaft position sensor. I'm hoping that this is the problem because its a really simple fix. Any thoughts/opinions would be appreciated. Thanks
Old Mar 7, 2011 | 05:47 PM
DavesZ#3's Avatar
DavesZ#3
Cam or crank position sensor sound quite familiar for the symptoms you describe.
Old Mar 7, 2011 | 08:38 PM
johnha209's Avatar
johnha209
happened to me like 2-3 months ago.. i changed the camshaft position sensor (bought it for $93 from stealership) and now its fixed.. just make sure u run codes to see and make sure u get the correct camshaft sensor cuz there are 2 of them and they arent the same.. good luck with fix =)
Old Mar 8, 2011 | 05:47 PM
MSBx03's Avatar
MSBx03
Thanks guys, bought the new sensor for 56 bucks at advanced auto. Swapped it out in about 30 min and everything worked.
Old Mar 9, 2011 | 01:31 AM
MSBx03's Avatar
MSBx03
OK, so I think the people at Autozone are idiots.. They might have sold me the wrong part, because it died on me again.. Is the bank 1 sensor the angled one or the straight one?? Please help.. I'm getting frustrated.. Nobody can seem to tell me. :[
Old Mar 9, 2011 | 05:51 AM
infamous350's Avatar
infamous350
this happened to me my slip lght and my abs were all on. I noticed i was a tiny bit low on brake fluid added some and everything went back to normal.
Old Mar 22, 2011 | 06:24 AM
Low Cash's Avatar
Low Cash
Same here! Car cold starts fine. Drive for a few minutes and the car losses engine power. The all 3 of those lights come on and stay on. But car runs fine after the lights come on and stay on. Its an 03 with ddk on the car and 22k on the motor. I looked around under the hood and everything seems to be plugged in. I did notice that tha tps on the throttle body had a hole in the top of the plastic. Could it be the tps? Seems like the car revs fine and everything, just all the lights on ate scaring me!
Old Mar 22, 2011 | 06:51 AM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Default codes
Have them check your codes with an OBD2 reader. If it is the camshaft or crankshaft sensor, the OBD2 codes will indicate which one (which bank). Field service manual for your year will indicate the maintenance steps for the different codes (which sensor needs to be replaced). I believe that there is a sticky for the FSM here in this sub-forum.
loudtoyz
Apr 6, 2023 04:52 AM
aarrgghh
May 1, 2022 11:04 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
350Z Project X
Oct 17, 2015 05:16 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
