Undercarriage shields / plates
Old Apr 18, 2011 | 07:54 AM
davide's Avatar
davide
Default Undercarriage shields / plates
I had my car towed in yesterday because during a drive in the country it started making a loud sound when hitting around 60mpg. (I had been going much faster earlier and had no issues). I pulled off twice but couldn't see anything wrong. I figured something came loose under the car and was flapping around when the air caught it. I had my wife follow me and she saw something flapping underneath on the passenger side. I stopped again but couldn't feel anything loose, but by that time, it was doing it at 40mph so I just called AAA and had the car towed in.
Apparently it's a plastic shield of some kind. At some point the part where the bolt holds it on came off (speed bump in the past?). They just took off the shield since there was no apparent reason for it to be there. Any reason to order a new part? Is it there aerodynamics? I'll try to post a photo tomorrow night.
Thanks
Old Apr 18, 2011 | 07:58 AM
huyrua's Avatar
huyrua
Yes it's for aerodynamics. IICR, those pieces were designed to lower the drag coiffecient when you're over 100MPH.
Old Apr 18, 2011 | 08:07 AM
davide's Avatar
davide
Well, I haven't taken it 100mph. Yet. Close though. If I don't hit 100mph, is it safe to say I don't need it?
Old Apr 18, 2011 | 08:19 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
if its the front undertray it also helps to direct air to the radiator to cool the engine.
flecko28's Avatar
flecko28
It also protects your engine bay from road debris
Old Apr 18, 2011 | 09:14 AM
Strollo22's Avatar
Strollo22
Get a new one... You could even get an aftermarket one they sell on here for $150.00
Old Apr 18, 2011 | 09:26 AM
davide's Avatar
davide
I'll see what part it is. The tech said it wasn't the big one under the engine. I won't be able to pick up the car until tomorrow morning, but I'll take a photo then and see what it is.
It was flapping pretty badly and making a lot of noise, so I didn't want to keep driving the car and risk doing actual damage to anything. Good thing I have AAA Plus. Hadn't used it in years though.
Old Apr 18, 2011 | 10:11 AM
ImWeeZzel's Avatar
ImWeeZzel
Sounds like its the undertray or a fender well liner. Theres no need to spend 150 for a undertray, just get a factory replacement. Contact my boy mike@conceptz, he offers better pricing than nissan courtesy.
Old Apr 18, 2011 | 10:37 AM
diablox1's Avatar
diablox1
the plastic pieces are not necessary such that your car cannot function without it. However, aside from the aerodynamic reasons for which they were designed, like was stated above, those pieces also protect your engine from crap and debris and water and whatever else might want to find its way up.
I'd replace them sooner than later but you can drive your car for sure, no problem.
Old Apr 18, 2011 | 10:54 AM
diablox1's Avatar
diablox1
oh, & are you related to davidv?
Old Apr 18, 2011 | 11:34 AM
Strollo22's Avatar
Strollo22
I had the "Main" undertray fall off my last car and I had it off for like 3 months and all my belts got destroyed... amazing what that piece of plastic does.
Old Apr 18, 2011 | 02:02 PM
Its there for a reason. Look at what is under the engine shield.
Old Apr 18, 2011 | 02:05 PM
Then there is little point in guessing what is missing and the function.
Old Apr 19, 2011 | 09:20 AM
davide's Avatar
davide
Picked up the car this morning. It's the M shaped panel discussed in this thread:
https://my350z.com/forum/engine-and-...component.html
I'll order another and replace this one. Here's what mine looked like with the plastic sheared off where one of the bolts went in. Quick fix once I get the new part. Thanks for the assist!
Old Apr 19, 2011 | 09:22 AM
davide's Avatar
davide
Oh yeah, that's a ZROC shirt (Columbus, Ohio club I just joined) and an empty Timmy Ho's cup from hot chocolate. :-) Those are my 35th Anniversary mats in the rear. I have Nismo mats covered with thick black carpet mats up front. Keep the special ones looking nice.
Old Apr 19, 2011 | 09:45 AM
davide's Avatar
davide
Thanks. I sent Mike an email with the car info and a photo of the part. Turns out that email is no good, so I'm trying directly through the conceptz site.
Old Apr 20, 2011 | 08:37 AM
davide's Avatar
davide
No comments about what this shield is for?
Old Apr 21, 2011 | 11:59 PM
Z Professional's Avatar
Z Professional
Uh...Shielding things? Sorry I had to. My caustic humor.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
