07 HR misfire due to oil change ?
Old Apr 22, 2011 | 01:40 PM
attackr1's Avatar
attackr1
Default 07 HR misfire due to oil change ?
Hi, Hope some HR owner can give me some advice
Had my car drop off at the local oil change place yesterday (Valvoline), and got my 07 HR oil changed with Valvoline sync power 5W30 (been using that for 2 years now). After i got home (about 5 min away from the shop), i experienced minor engine stall (didn't pay too much attention).
Next morning, i start the car in cold (72F), experienced major engine stall during idle. The engine die twice, no throttle response . The problem soon got better when engine is fully warm up. on my way to work, cruising down hwy in 6th gear around 75mph, the rpm started to hesitate and jump between 2500 and 3500 rpm for 2 seconds and it went back to normal. Took it to the shop and did the diagnostic and got misfire on the meter. I then went back to the oil change place and had them redo the oil change @ 5 quarts only(I was worry they overfilled my engine oil the first time). unfortunately, the problem still there. I am going to change the spark plugs just to see if it gets better. i will post the result tomorrow.
All advice are greatly appreciate.
Steve
Old Apr 22, 2011 | 02:13 PM
No. Its just motor oil.
Old Apr 22, 2011 | 02:45 PM
attackr1's Avatar
attackr1
so you mean the oil change place did overfill the engine oil, if i understand your reply correctly.
Old Apr 22, 2011 | 05:14 PM
winchman's Avatar
winchman
If they really did overfill the oil, the excess oil can get whipped into a froth which can be carried into the intake system through the PCV valve. That will foul the plugs and cause the misfiring.
Now that the excess oil has been removed, the engine should gradually clean itself of the carbon buildup. If the car is drivable, I'd drive it for several hundred miles to see if it gets better. If it does, you're OK. If not, you'll need to change the plugs, etc.
I'd inform the shop about what you're going to do, and let them know you expect them to pay for fixing your car if the problem doesn't go away after several hundred miles.
Old Apr 22, 2011 | 05:35 PM
attackr1's Avatar
attackr1
thanks winchman & davidv
I already purchased and installed the plugs. cost me $25 each X 6 and 2 hours . i did see some oil on 2 of the old plugs i removed, and hope that's the reason for all my misfire problems. i will post the result tomorrow when i finish the project.
I guess i will have to change my car oil again like old days.
BTW, if anyone need a write up for HR spark plugs change and pictures, pm me, and i will do a complete post with pictures. it's a pain in the @#$
Thanks
Steve
Old Apr 22, 2011 | 05:59 PM
drivessidewayz's Avatar
drivessidewayz
$25 each!? What the hell are you running? Lol
Old Apr 22, 2011 | 06:02 PM
attackr1's Avatar
attackr1
from nissan dealer OEM style NGK Laser Iridium plugs
Old Apr 23, 2011 | 12:37 AM
winchman's Avatar
winchman
OUCH!! Would have been about $9 each at NAPA, etc.
I was hoping you'd be able to avoid spending money on something you didn't really need.
Please let us know what happens with the new plugs.
Old Apr 23, 2011 | 02:18 AM
0jiggy0's Avatar
0jiggy0
Lmao who goes to the dealer for spark plugs?
Old Apr 23, 2011 | 02:08 PM
attackr1's Avatar
attackr1
quick update, changed all plugs and it ran great! CEL gone, no more engine stall and misfire. now i am going back to the oil change place to have them pay for the plugs
Thanks for all helps
Steve
Old Apr 23, 2011 | 09:33 PM
winchman's Avatar
winchman
That's good news.
Good luck with the lube shop. Probably the best they'll offer is a couple of free oil changes.
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
