Cel / slip light...help!!!
Old Jul 24, 2011 | 05:33 PM
Raceism's Avatar
Raceism
Default Cel / slip light...help!!!
I was making a left onto my street and it started sputtering, throwing CEL and SLIP... I pulled into the driveway then the car stalled in neutral... I've fired it back up but I had to keep the rev up for about 5 seconds for it to stay on.
I doubt it's batter related because I've gotten it replaced a few days ago.
Anyone with similar experience or any knowledge about this issue??
Thanks!!
Old Jul 24, 2011 | 06:00 PM
amr_electron's Avatar
amr_electron
Do yourself a favor & get the CEL code scanned first !!!
Old Jul 24, 2011 | 06:32 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Let us know once you've had the code scanned. Any Pep Boys, AutoZone, Advanced Auto, etc. will scan the code for free.
Old Jul 24, 2011 | 06:55 PM
Raceism's Avatar
Raceism
I've just performed the CEL code check procedure that one of the forum members suggested (pretty much same as to reset ECU). I've counted how many times CEL light blinked between each short paused...it was "3", "4", "5".
What kind of CEL code is that?
Thanks!!
Old Jul 24, 2011 | 06:57 PM
Raceism's Avatar
Raceism
btw...ECU has been reset and the those lights disappeared. Hoping it wouldn't come back...will it??
Old Jul 24, 2011 | 07:01 PM
SparkleCityHop
Living in 350Z
List of all codes is here: https://my350z.com/forum/maintenance...d-generic.html
Your code: P0345 Camshaft Position Sensor 'A' Circuit (Bank 2)
Instructions for changing Camshaft sensor is in FSM: https://my350z.com/forum/maintenance...anual-fsm.html
Old Jul 24, 2011 | 07:04 PM
SparkleCityHop
Living in 350Z
You'll need to change the sensor or it will come back. Very common.
You can search for "P0345" or "Camshaft Sensor" to find more info.
An example thread that I found using Search: https://my350z.com/forum/maintenance...k-2-error.html
Old Jul 24, 2011 | 07:13 PM
Raceism's Avatar
Raceism
Thanks Sparkle!!!
Old Jul 24, 2011 | 07:26 PM
SparkleCityHop
Living in 350Z
no prob. that was one of the first problems that I had with my car. exact same code.
Good luck, neither the camshaft or crankshaft sensors are that hard to get to if you have some wrenches or a socket set. It's definitely something that you can do yourself once you have the replacement sensor.
Old Jul 24, 2011 | 07:32 PM
Raceism's Avatar
Raceism
it seems like there was a re-call on Camshaft Position Sensor for '03 Z's. You think I can just call and take it into the dealer? perhaps they'll replace it for free???
http://www.dealerrater.com/recalls/Nissan/350Z/#y2003
loudtoyz
Apr 6, 2023 04:52 AM
aarrgghh
May 1, 2022 11:04 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Bigsyke
Sep 11, 2015 06:19 PM
Darkspy
Sep 7, 2015 09:09 PM
