kit for pressure bleeding clutch and brakes
Old Aug 10, 2011 | 08:50 PM
SlowInFastOut's Avatar
SlowInFastOut
Default kit for pressure bleeding clutch and brakes
I need to bleed the clutch, and later on brakes. Anybody had luck with a pressure bleeder, e.g. Motiv? The web page does not list Nissan specifically. I'm having a hard time figuring out how to attach a hose to the clutch reservoir (not a threaded connection, just a squeeze-on cap).
Thanks.
Old Aug 10, 2011 | 09:41 PM
gabe3d's Avatar
gabe3d
Ford Three Prong Adapter 1107 is the adapter that fits for the brake cap for our cars. I don't remember if it is the same size as the clutch one. By the way, I also have the universal one and it's not very good, so stay away from it.
Old Aug 11, 2011 | 03:15 AM
DavesZ#3's Avatar
DavesZ#3
Lots of threads here on the Motive. As mentioned above, the 1107 fits our reservior perfectly.
Old Aug 11, 2011 | 06:02 AM
thekinn's Avatar
thekinn
unless you replace the reservoir, i think you'll need a second person to bleed the clutch. My fiance just helped me bleed my clutch last night.
Old Aug 11, 2011 | 06:11 AM
350zion's Avatar
350zion
Professional
The motive was the best money I spent.. Found mine on Amazon, got it in like 3 days.. Cheaper than anywhere else.. i forgot the part number but it uses a universal round top with j-hooks to hold it on the res...
I did my clutch mc with new ss line alone in like 10 minutes.....
Old Aug 11, 2011 | 08:44 AM
DavesZ#3's Avatar
DavesZ#3
I do my clutch manually because of the difficulty of trying to use the adapter on the clutch reservoir. there's such a small amount of fluid anyway it's easy to do manually - but you do need two people.
Old Aug 11, 2011 | 10:36 AM
350zion's Avatar
350zion
Professional
I bought mine originally to jus get the job done then I planned on selling it..
Instead I bought the adapter to fit my truck n used it on that jus recently.. I don't think I'd part with it jus because it makes the job so much simpler.....1 man job trust me!
Old Aug 11, 2011 | 11:05 AM
drivessidewayz's Avatar
drivessidewayz
You can one-man the brakes, but not the clutch. Their universal adapter is crap imo. Some people will change the clutch reservoir in order to use the motiv bleeder there too.
350zion I'd love to see how you had it arranged; unless your year places the clutch reservoir in a different place than mine...
Old Aug 11, 2011 | 01:17 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I have read multiple times recently that power bleeding the clutch doesn't work very well, and that a long, slow, manual bleed is the way to go.
Old Aug 11, 2011 | 03:22 PM
J 0 K 3 R's Avatar
J 0 K 3 R
even for brakes the kits are a pain and dont work that well. i picked up the most expensive autozone kit and it didnt give me any confidence that the lines were bled correctly, i ended up waiting for a friend.if your friends are busy best bet is to go down to the 'illegal allien looking for work' street corner of your city and pick up someone that looks like they can get a peddle to the floor. youll be helpin out someone that needs a little cash and get the help you need.(tried to replace my brakes with my mom bleeding the brakes one time, she didnt have the strength to push the peddle all the down lol. ps no i dont live with the rents lol they just have a nicer garage than me) thought id share my experience.
Old Aug 11, 2011 | 03:59 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
then you bought the wrong kit
The Motive works flawlessly, have used it countless times, and it's something anyone who does their own maintenance on their cars should have. Bleeds it effectively, quickly, cleanly and without incident.
Old Aug 11, 2011 | 05:12 PM
ChuckW's Avatar
ChuckW
I'm really pro-Motive.
Works great with the Nissan adapter. I had no problem using the universal adapter on the wife's former Honda.
The last thing I need is someone forcing the master cylinder seals all the way to the bottom where the sleeve has never seen wear. That, typically, requires a master cylinder rebuild in a short while.
Excellent product and I didn't have to rely on anyone. I've used it three times and I felt like the first time - it paid for itself.
Old Aug 11, 2011 | 05:38 PM
drivessidewayz
Depends on the year. ie:06 is bled very differently from 07. Can bleed mine in 20 minutes with a friend now that I actually found the correct way to bleed it.
Old Aug 11, 2011 | 08:00 PM
SlowInFastOut
thanks guys; I did some search, but opinions on the universal adapter 1101 for the clutch are divided.
Anybody would like to comment?
samansharif
Sep 25, 2015 12:31 PM
