HELP! Engine GURUs, please help with po300 and po302
Old Sep 9, 2011 | 08:08 PM
SuperBlack350z's Avatar
SuperBlack350z
Default HELP! Engine GURUs, please help with po300 and po302
hey guys, need some help. My Z rarely gives me any problems since the day i bought it. Here is a little background.
Everything was fine. I just moved to a new house and i let my Z sit here for about three weeks straight without driving it. In this time, hurricane irene hit us last week with a lot of rain, wind, etc. but still, i never started up the car during this time .
the car was left with little gas. not where the gas light was on but it was low. Also, in this time , before parking it for three weeks, i had a really bad exhaust leak since i broke my exhaust piping. it was bad enough where it sounded horrible .
Well today i started her up tonight and the idle was bad. like it died a couple of times then i just revved her up and then started to drive. well the SES light came on and was blinking. I reparked and checked the codes..
p0300 - random misfires
p0302 - misfire cylinder 2
the idle is pretty damn bad right now. Should i reset my codes to see if it comes back on?
i'm guessing it could be
-bad gas/low gas wiht condensation
- a bad coil pack
- exhaust leak causing something
like i said, i park and leave my car there for long periods of times all these years of owning my car but this time the only difference is that i have a bad exhaust leak before parking it and also a hurricane hitting us.
any help?
Old Sep 9, 2011 | 11:40 PM
R350Zz33's Avatar
R350Zz33
put some fresh gas in highest rating u can get throw some octane booster in her ecu reset enjoy
Old Sep 10, 2011 | 12:32 AM
Mcutali's Avatar
Mcutali
Exclamation hmm
check plug gap, clean em up. throw in some HEET or i think its actually iso heet it removes water, id put in some fresh 93 and and i always throw in nos booster or turbo108.
Old Sep 10, 2011 | 10:19 AM
SuperBlack350z
i'll try some of those tips. thanks guys.
anyone else have had this problem?
Old Sep 11, 2011 | 06:10 PM
SuperBlack350z
bump
Old Sep 11, 2011 | 06:46 PM
0jiggy0's Avatar
0jiggy0
Where is the exhaust leak. See if any of the coils got wet. I don't think ur gas went bad in 3 weeks. And the octane booster advice is just stupid. Can't hurt filling her up tho.
Old Sep 11, 2011 | 07:06 PM
SuperBlack350z
both flex pipes, the mid pipe has a big hole and the rear main muffler. pretty bad leaks. you can hear it pulsate from under the car before it started messing up.
weird thing is, i reset the engine light, the problem went away but not sure if its going to come back. didin't drive it but idle became perfect after i reset the light.
Old Sep 16, 2011 | 02:20 PM
lafingas's Avatar
lafingas
Yo..i had P0300 when i bought toby's z too. Mine was a vacuum leak in the intake manifold. You might want to make sure those bolts are tight. Also...my z does the same....I park mine for a week or two with out driving it. As soon as i crank it up...ses light comes on with p0300
I gota drive the car till the engine gets warm then reset the ecu. After ecu reset..... it usually does the trick...until i park the car again for a week or two.
Old Sep 16, 2011 | 08:19 PM
SuperBlack350z
with his engine, it's leaking because of that crappy gasket material that he used for it, lol. the bolts are stripped out.
i put in new gas, the car runs fine. i think i had some hillbilly gas in it from filling it up in the country area around here. i'm still going to get some new coil pack anyways. I never get problems with this car so i guess i get annoyed when something comes up.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
