sound of hitting rev limiter
Old Oct 26, 2011 | 12:05 AM
JDMStanced's Avatar
JDMStanced
Default sound of hitting rev limiter
i'm hearing the sound of hitting rev limiter around 4500 RPM.
This doesn't happen all the time though. when i launch straight away, shift to 2nd and drop the clutch, i hear the sound.
With the sound of wa dah dah dah dah!!, the car loses power.
OH! is this caused by slipping clutch? i tested it out on the freeway (going around 60mph, and downshift to 3rd?. no slipping there).
Old Oct 26, 2011 | 12:23 AM
scoobyrex247's Avatar
scoobyrex247
maybe your car is in limp mode. Do you have a cel?
Old Oct 26, 2011 | 12:30 AM
ESP350Z's Avatar
ESP350Z
Traction control?
Old Oct 26, 2011 | 12:46 AM
JDMStanced's Avatar
JDMStanced
no CEL.
I have the vdc completely off switch mod. so the slip light and the vdc lights are on.
Old Oct 26, 2011 | 02:11 AM
ESP350Z's Avatar
ESP350Z
How long since that mod did it take for this issue to start
Old Oct 26, 2011 | 11:06 AM
JDMStanced's Avatar
JDMStanced
i didn't have this problem until i crashed a couple of times at a track
This mod was working great, and i don't think this is causing the problem ?
Old Oct 26, 2011 | 01:07 PM
Cass007's Avatar
Cass007
Pull codes from the ecu, you may have jumped a tooth on the flywheel.
So the issue is only from first to second? Is it at hard shift or in second as it gains speed? Happens every time or only once in a while?
Old Oct 26, 2011 | 01:49 PM
JDMStanced's Avatar
JDMStanced
only from first to second. it happens when I hard shift n drop the clutch.
it happens most of the time in straightaway. I have to launch hard in first gear, then hard shift. happens most of the time.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
