Snapped Drive Shaft
Old Nov 28, 2011 | 07:47 AM
SLIdEwAyZ25's Avatar
SLIdEwAyZ25
Originally Posted by TimsZee
Those look like they are gunna be a PITA to install..
honestly with the drive shaft out it's going to be a peice of cake.
but have you ever checket the clearence of your drive shaft to your exhaust flanges? i had one contact my drive shaft going really slow when i bottomed out in a parking garage, it put a tiny tiny ring grove in my drive shaft.
Old Nov 28, 2011 | 09:15 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
The diff bushings are cake. Subframe SUCKS the 1st time you do it. Getting the subframe out is easy, but getting the old bushings out can be a PITA. The 1st time I did it, by the time I got to the last bushing it was a walk in the park. I learned little tricks on each of the previous ones. Getting it back in is easy just make sure everything is completely lined up. If it goes in crooked, you can end up wedging it in there. Ask me how I know : /
Old Nov 28, 2011 | 10:32 AM
djamps's Avatar
djamps
The only thing I can thing of that might have played a roll in it would be the burnout. I had some minor wheel hopping, maybe one hop to much..?
Two words for the 6MT guys -- bias ply's. All the upgrades in the world won't keep **** from breaking that one time the track prep is a$$ and your radials start hopping or not enough pre-load on your launch.
I haven't had a single instance of wheel hop or dead hook since switching to bias ply's (it was terrible on radials)... drivetrain is 100% stock to the bushings. Dozens of passes including a handful of 1.6-1.7 60ft's and my diff bushing isn't bleeding yet .
Old Nov 28, 2011 | 11:22 AM
nathanwl2004's Avatar
nathanwl2004
the universal joint does not come apart. it is all one unit. the new drive shaft should have a universal joint attached to it. super easy to install and remove.
Old Nov 29, 2011 | 02:27 AM
MR RIZK's Avatar
MR RIZK
Probably had something impact the DS during normal driving and weakend the structure. The FSM highlights the fact it shouldn't be dropped. Just unlucky..
Old Nov 30, 2011 | 07:36 AM
2bad240's Avatar
2bad240
i was there when it happened. he had a lil water on the tires from the burnout pit and when he took off it spun real bad and then caught about 6 foot out and broke. i guess maybe something could have hit it before and weakened it and the shock broke it.
Obadabot
Jun 18, 2023 11:31 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350Z_Al
Oct 29, 2020 07:44 PM
Depravity
Oct 1, 2015 04:49 PM
