Metal on metal sound when hard turning??
Old Dec 7, 2011 | 01:42 PM
Colombo's Avatar
Default Metal on metal sound when hard turning??
alright well at the last autox i noticed after a run or 2 that when i turned real hard to the right it would make a scrapping metal on metal sound. only happens when turning right and only happens w hard turning. rotors are new as are pads and problem persist. check all my bushings underneath and everything LOOKS ok. any ideas? wheel bearing? other issues?
Old Dec 7, 2011 | 07:38 PM
JDMStanced's Avatar
JDMStanced
prolly bearings
Old Dec 7, 2011 | 08:26 PM
terrasmak's Avatar
LCA bushing is probably bad
Old Dec 8, 2011 | 07:49 AM
Colombo's Avatar
how would i check if the lca bushing was bad? and i did the wheel bearing check w the side to side n up n down play and it has none not to mention doesnt have the typical bearing noise.
Old Dec 15, 2011 | 09:26 AM
bikinilust's Avatar
bikinilust
go under the car and look for tears on the lca bushings... the lower/inner bushing on the lca is prone to blowout...as well is the compression rod bushing
If they're blown, energy suspension front end bushing set is the most economical poly bushing set
Old Dec 15, 2011 | 09:38 AM
JasonZ-YA's Avatar
JasonZ-YA
There are two lower control arms: transverse link and the compression arm:
Look for this...odds are it's the inner translink bushing, as the compression bushing tears, but doesn't make contact with metal on turns, the translink on a hard turn will be forced forward or aft due to the compression arms articulation and influence, braking loads, will slide it fore and aft.
Look for this:
https://my350z.com/forum/brakes-and-...ight=translink
-J
Obadabot
Jun 18, 2023 11:31 PM
lapham3
Oct 7, 2022 03:15 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
