Necessary to turn rotors when doing brake pads?
Old Dec 15, 2011 | 08:20 AM
BigD2k5's Avatar
BigD2k5
Default Necessary to turn rotors when doing brake pads?
Got my OE pads for the front and rear and looking to do my brakes this weekend. I called around and turning rotors are $15 ea but it can take almost 3 hrs. I'm needing someone to help me do the job and use their tools but don't want to sit around doing nothing for that long. A friend recommend just scuffing up the rotors to get any glaze off. I've done brakes before and turned them both times (different vehicles) because it didn't take that long and were a lot cheaper back then. Opinions?
Old Dec 15, 2011 | 08:21 AM
BigD2k5's Avatar
BigD2k5
FYI--60k on the odom and it's the first time doing the pads.
Old Dec 15, 2011 | 08:48 AM
DavesZ#3's Avatar
DavesZ#3
Necessary? Not always. Recommended? Probably.
If they are scored or grooved, then you probably want to have them resurfaced. If they are warped and there's enough material left, you definitely want to do it. If they are really worn (which I would suspect with 60Km on them) they might be too thin and really need to be replaced. BTW - $15 is a pretty good price.
Old Dec 15, 2011 | 09:43 AM
No it is not necessary to turn the rotors. Neither is it necessary to replace motor oil every 5,000 miles. Or periodically check tire pressure and coolant level.
Old Dec 15, 2011 | 11:35 AM
bmccann101's Avatar
bmccann101
i get cheap rotors and swap the whole set up every time. 169 bucks for all four ceramic pads and slotted rotors, good steel, zinc coated, countersunk and chamfered holes etc.
Never a single issue.
i do it every year becuase im cool like that.
Old Dec 15, 2011 | 01:10 PM
122554's Avatar
122554
Where do you get em? I'm due. Thanks
Old Dec 15, 2011 | 01:21 PM
bmccann101's Avatar
bmccann101
http://www.brakemotive.com/listings/...SAN/350Z/7078/
Old Dec 15, 2011 | 03:28 PM
122554's Avatar
122554
Thanks
Old Dec 15, 2011 | 10:52 PM
I generally keep a set of front rotors ready to install. This way I have no downtime turning rotors. You can always sell or giveaway extra rotors.
samansharif
Sep 25, 2015 12:31 PM
