leaking fluid near the rear diff
Old Mar 6, 2012 | 08:45 PM
dkorr's Avatar
dkorr
Default leaking fluid near the rear diff
So I was bleeding my brakes last night and when I jacked up the rear pumpkin I found this strange leak coming out of this cross member. You guys have any idea what this could be? the liquid appears to be dried up and some even splashed onto the bottom of the muffler as well as pipes.
Old Mar 6, 2012 | 09:28 PM
Waiz's Avatar
Waiz
Moved
It could be the differential breather, diff bearing, or an overfill of fluid
Here are a few threads about it:
https://my350z.com/forum/maintenance...wn-source.html
https://my350z.com/forum/maintenance...aking-oil.html
https://my350z.com/forum/maintenance...-clicking.html
Old Mar 6, 2012 | 09:34 PM
JasonZ-YA's Avatar
JasonZ-YA
Hands down thats a blown rear diff bushing..look at where its coming from....
its not the diff breather as that gets plumbed to a 90 degree plastic elbow that lets the fluid poor INSIDE the subframe to never be seen again, it wouldnt pour from where your showing.
read my suspension 101 thread on replacing the rear subframe bushing with a solid aluminum subframe bushing.
there are also other crappy urethane options out there that i dont readily agree with but its your car.
you cant buy a bushing from nissan, they only sell the entire rear subframe.
but the solid diff bushings and call it a day.. many threads on them, check it out.
-J
Old Mar 6, 2012 | 09:36 PM
JasonZ-YA's Avatar
JasonZ-YA
see here:
https://my350z.com/forum/engine-driv...ushing+install
https://my350z.com/forum/drivetrain/...-in-stock.html
-J
Old Mar 7, 2012 | 08:30 AM
dkorr's Avatar
dkorr
Just made some calls. Unfortunately there's no TSB and it's not covered beyond the 3yr/36,000 warranty period.
Old Mar 7, 2012 | 09:12 AM
bmccann101's Avatar
bmccann101
correct. Even a TSB doesnt mean its coverd or a recall etc....welcome to paying to upkeep your car.
Old Mar 7, 2012 | 11:51 AM
CircleHeartX's Avatar
CircleHeartX
i had the same thing happen to me right around that ring last year. Wasn't much of a leak and it was really dry when i noticed it. I just cleaned it and it seems to never leak again?
How sever is this probleam? car feels fine and no noises
Old Mar 7, 2012 | 11:52 AM
bmccann101's Avatar
bmccann101
^^ whatever floats your boat, but if its leaking, its broken.
Your choice to repair it or not.. it is there for a reason.
Just wait until your shifts start banging the rear end around against the frame.
Old Mar 7, 2012 | 12:20 PM
CircleHeartX
Yeah... That's why i was wondering how severe it is and what probleams will i run into.
Looks like some work to do a DYI.
Old Mar 7, 2012 | 12:22 PM
bmccann101's Avatar
bmccann101
not worth it as a DIY unless you are fully shopequiped etc.. its not a driveway job.
Faster to drop who subframe off the car. UsuAlly charge 4-6 hours.
Old Mar 7, 2012 | 01:01 PM
CircleHeartX
Really... Cha-ching!!$$$$, Thats a problem. Well Guess ill have to wait this out and get it done in the future sometime when the wallet swells up.
Old Mar 7, 2012 | 07:28 PM
drivessidewayz's Avatar
drivessidewayz
I did it myself under my car last winter. It's completely doable yourself, though I'd not like to do it again. From what I recall it required 4 jack stands, a jack of some sort, basic tools, a metal saw, a freezer, and a BFH.
Old Mar 7, 2012 | 09:26 PM
dkorr's Avatar
dkorr
From what I gathered it's not something you want to ignore for too long. It might be even costlier in the long run. After calling a few shops they quoted $600-$700 (takes 6-7 hrs) not including the $150 SPL bushings. They also recommended changing the front bushings as well since they're pulling the whole carrier out and might have to replace those eventually anyway. I was told it'll be noisier with the solid bushing (but there's no other alternative).
Old Mar 8, 2012 | 07:07 AM
JasonZ-YA's Avatar
JasonZ-YA
I posted the DIY on post #4??? its very DIY able....
to each their own...
Originally Posted by JasonZ-YA
-J
Old Mar 8, 2012 | 10:20 AM
dkorr's Avatar
dkorr
-J
Is this all I need? http://www.z1motorsports.com/350_g35...oducts_id=5229
I know I'm suppose to change out the front bushings at the 'ears' since they're pulling the whole carrier out anyway. I didn't know Energy makes both the front and diffr bushing. I read somewhere that SPL makes the best diffr bushing while Whitline makes the bushing for the ears.
